Horizontal Tension Force equation
The discussion centers on the concept of horizontal tension forces, particularly in scenarios involving equal systems such as a string or cable pulled from both ends. Participants explore whether there is a standard formula for calculating tension in such cases, using examples like rose petals and cotton strings. The conversation includes theoretical considerations and implications of forces acting on the system.
  • One participant questions if there is a standard formula for horizontal tension in systems like a string between two equal forces, using the example of rose petals pulling apart.
  • Another participant suggests that tension in a string depends on how hard it is pulled, implying that the force exerted by the petals would determine the tension.
  • A participant proposes a hypothetical scenario where each petal exerts a force of 123 kN, questioning if a formula exists for this action, while noting that the cotton string's weight is negligible.
  • One participant explains that tension in a rope or string is equal to the force applied at either end, emphasizing the concept of equilibrium in the absence of acceleration.
  • Another participant discusses the relationship between forces acting on a string, stating that if the forces are equal, the tension is equal to the force applied, but if they are unequal, the string would not remain stationary.
Participants express differing views on the nature of tension in the presence of unequal forces. While some suggest that tension remains the same at both ends in certain conditions, others argue that unequal forces would lead to movement, indicating a lack of consensus on the application of tension in these scenarios.
Participants mention various assumptions, such as the negligible weight of the cotton string and the equal forces exerted by the petals. There is also a discussion on the implications of gravity and friction, which are noted as factors that could influence the tension but are not resolved within the discussion.
This discussion may be of interest to individuals exploring concepts of tension in physics, particularly in the context of forces acting on strings or cables in equilibrium and non-equilibrium scenarios.
karen_lorr
TL;DR
Horizontal Tension Force equation between two equal (pulling) forces
(not a homework question - I left education over 45 years ago)
Hi, this just out of interest as I have been googleing this and can't find the answer
I know the equation for tension force, for example a weight on a string, block on a ramp, etc.
But is there something similar for a horizontal pull (on a cable, string, etc) between two sides of an equal system. For example, a belt buckle – I know silly example or even a string between your outstretched arms.
Let’s say you (somehow) attached a piece of cotton to the petals of a rose. In the morning the rose would open. The petals would move apart. The cotton would have a tension (pull between the petals). Even if one petal was larger (more mass, more pulling power, etc) the tension on the cotton would be the same at both ends.
Is there a standard formula for this?
I hope this make sense.
Thank you
Mathematics news on Phys.org
If you hold a piece of string horizontally and pull at both ends, then the tension depends on how hard you pull.
I can't imagine rose petals could generate much pulling force, but then horticulture isn't my strong suit!
You’re probably right about the rose.
But let’s say each petal opens from the centre with a force of 123kn (very strong roses).
There are two petals each pulling with the same force.
The cotton is not massless (as infinite acceleration hurts my brain), so let’s say it has a weight which is so small it hardy affects the outcome.
The gravity on each petal is the same as the normal force, so is cancelled.
Is there a formula for this type of action?
The tension in a rope or string is equal to the force applied at either end. That's where there is equilibrium.
I guess the equation you know is ##F_g=mg##.
Tension is basically a force (##F##). The previous equation is a special case for a mass (##m##) where the force due to gravity (##F_g##) would cause an equivalent acceleration ##g##, if unopposed by another force.
But this equation is a special case of a more general equation:
$$\sum F = ma$$
Where ##\sum F## is the summation of all forces in one direction and ##a## is the acceleration of a mass ##m## in the same direction.
But it is possible to not have an acceleration, i.e. ##a=0##, therefore ##ma = 0## and thus ##\sum F = 0##.
That last equation means that there are at least 2 forces that are equal and opposite. For example:
$$F_1 + \left(-F_2\right) = 0$$
##F_2## has a negative sign to show that it goes in the opposite direction of ##F_1##. So this equation basically states that ##F1## and ##F_2## must have the same magnitude, the same numeric value. If each one of these forces are acting on opposite end of a string, the string will be under a tension of magnitude ##F_1## (or ##F_2##, since they have the same value).
If ##F_1## and ##F_2## are of different magnitudes, then the acceleration ##a## cannot be zero. Therefore the string would begin to move. The sign of the acceleration would dictate the direction of the acceleration. Note that if accelerations are not involved, the mass is irrelevant.
Since we're looking at the horizontal forces only, the previous equation applies where each petal pulls one against each other.
The tension in the piece of cotton would be 123 kN (##=F_1 = F_2##).
Mass is irrelevant in this case as the acceleration would be zero.
The gravity is irrelevant here since it acts only in the vertical plane, which is perpendicular to the plane we are looking at in the present case.
But we can analyze this vertical plane also where ##F_g = ma## or ##mg = ma##. This would mean that the piece of cotton is under acceleration (##a=g##) and should slide down the petals. If it is not the case, then it is because there is another force involved, in this case, most likely friction ##F_f##. The equation is then:
$$F_g + \left(-F_f\right) = m(0)$$
Or:
$$ F_g = F_f$$
So the friction force is equal and opposite to the gravity and the acceleration is zero.
If the string is acted upon only by two unequal forces at its ends, it wouldn't remain stationary. By analogy, in a tug-of-war, the stronger side wins by causing the rope to move.
Were you expecting to find a formula for the tension on a string acted upon only by unequal forces at each end? A net force in one direction would act on each section of such a string. That net force wouldn't be called a "tension" since the word "tension" implies a balance of forces.
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 19 ·
