Hot Air Balloon Free Fall Question
A hot-air balloonist releases a sandbag at a height of 40.0 m while ascending at 5.00 m/s. To find the position of the sandbag 0.165 seconds after release, the correct formula is x(t) = x(0) + v(0)t + 0.5at^2, with downward acceleration due to gravity as -9.80 m/s^2. The initial upward velocity must be accounted for, leading to a position calculation of approximately 45.33 m. For velocity, the formula v(t) = v(0) + at is used, emphasizing the importance of sign conventions in the calculations. Understanding these principles is crucial for solving motion problems involving free fall.
COCoNuT
A hot-air balloonist, rising vertically with a constant velocity of magnitude v=5.00m/s , releases a sandbag at an instant when the balloon is a height h=40.0m above the ground . After it is released, the sandbag is in free fall.
1.) Compute the position of the sandbag at a time 0.165s after its release. Take the free fall acceleration to be g=9.80 m/s^2. answer ___ m.
how would i find that? i don't know where to start...
i tryed to find the highest time that it takes, 5.00/9.8 = 25/49
im just doing random things for hours, can someone point me to the correct way?
For one dimensional motion with constant acceleration (a) the following formula gives you the position (x(t)) of the object as a function of time (t):
x(t)=x(0)+v(0)t+\frac{1}{2}at^2
Where v(0) is the initial velocity of the object. Be careful with the signs of the paramters!
so...
x(t)= 40m + 5.00 + 1/2(9.80)(0.165)^2 = 45.33m <-- am i doing it correctly?
EaGlE said:
so...
You forgot to multiply the initial velocity with time. And also, you chose your inital velocity positive meaning upwards, but the acceleration has another direction, downwards. So you have to use a=-9,8 m/s^2.
[The formula comes from Newtons second law F=ma, with F the gravitational force mg, so mg=ma -> g=a=v'=x'' where ' denotes a derivative with respect to time. When you integrate the constant g two times with respect to time (using the appropriate boundry conditions (initial position/velocity)) you get the position as a function of time, the formula I gave you.]
thanks, that worked. i have another question.
Compute the velocity of the sandbag at a time 0.165s after its release. Take the free fall acceleration to be g=9.80m/s^2 .
i just need to know the formula i should use.
i tried this formula: v(x) = sqrt(v(0)^2+2ax)) which doesn't work
velocity is the derivative of the poition to time:
\frac{d}{dt}[ x(t)=x(0)+v(0)t+\frac{1}{2}at^2 ]
v(t)=\frac{dx(t)}{dt} = v(0) + at
Again, wach out with the signs...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
