Hot Air in Jet Engines: Fuel Burn and CO2 Formation
The discussion centers on the emissions produced by jet engines, particularly focusing on the formation of CO2 and other gases during fuel combustion. The primary components of exhaust gases include carbon dioxide, water vapor, and nitrogen oxides, with CO2 being a major product of fuel combustion. The heat from burning fuel spreads quickly to the surrounding air, impacting turbine inlet temperatures rapidly. Nitrogen oxides (NOx) are highlighted as significant pollutants, especially since jet engines release them at high altitudes, contributing to ozone layer damage. Overall, the continuous combustion process in jet engines results in complex emissions that have immediate and long-term environmental effects.
sid_galt
When fuel is burnt in the jet engine, what is the major component of the hot gases thrown out of the back - the CO2 formed (I know CO2 is not the only component but it is the major one) from the fuel or the air entering the jet as a whole?
In other words, does the heat of the burning fuel spread very quickly to the surrounding air in the jet or does it take a lot of time?
Basic turbine emissions are Oxygen, some trace inert gases, water vapor and carbon dioxide. When we do emissions testing for our certification programs the basic areas we focus in on are:
- CO (carbon monoxide)
- NOx (oxides of nitrogen)
- smoke
- Unburned hydrocarbons
The basic fuel used in civil aviation is JET-A which is a kerosene based fuel.
I'm not quite sure what you are asking here. The cycle is a continuous process, so once it starts, it is constantly going. Obviously, the rate at which the heat gets to the airflow in the engine will depend on quite a few things, but the effect happens quite quickly. Turbine inlet temps (ITT's) can spike up in less time than it takes your eyes to notice it has happened.
H20 makes up the majority of just about any fuel being burned.
I'd suggest atmospheric nitrogen...
In addition to what Fred has said, I would say the main damage of Jet turbines are NOx. Although all heat engines exhaust NOx, Jet turbines are the unique which do this at high altittude.
Usually NOx compounds need a lot of time (of order of years) to reach high atmospheric layers. On the other hand, jet engines exhaust NOx just at high heights saving up that time of delay and damaging the Ozone Layer.
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
