How to Calculate Hot Water Supply for a House?
To calculate the hot water supply for a house, it is essential to understand the specifications provided. The requirement is to deliver 15 gallons of water at 110°F within 10 minutes, with 16 water draws over a week, totaling 240 gallons. Each "load" for the dishwasher refers to one complete use, and if it uses 15 gallons per load, five loads would require an additional 75 gallons. The discussion highlights the need for clarity on the total water usage and suggests using solar thermal panels for heating. Accurate tank sizing will depend on the total calculated water demand based on these specifications.
Weicheng
HI i am a student from Singapore , and i was told to calculate the amount of hot water needed to supply to a house. The design brief stated
1)Deliver 15 gallons of water at average 110°F (43°C) temperature within 10 minutes; 16 water draws during 1 week
2)Dishwasher: Successfully wash five loads of dishes during 1 week
Whats does this specs means? 16 draws means 15 gallons X 16 in a week? also for dishwasher what does it means 5 loads?How do i know how many gallons would it use? Our lecturer had not idea and only asked us look online. I hope you guys could help us. Our rough idea is just solar thermal panels( compulsary thermal instead of PV) , maybe 2-3 panels and a tank. Tank sizing is a porblem too.
A "load" refers to the act of loading the dishwasher and then using it. It is the same as "doing a load of laundry"/
So 5 loads means five uses of the dishwasher.
To "draw water" is a term not used often. Most commonly, people will say "I'm going to draw a bath" meaning they will fill the tub with water.
So I would say that 16 "water draws" means 16 uses.
Are questions 1 & 2 both referring to a dishwasher?
Could you post the full question?My guess is this:
1: every "draw" or use is 15 gallons. 16 uses is 16*15 = 240 gallons needed that week.
2: if the dishwasher uses 15 gallons per use, 10 minutes long... 5 loads will be 5* 15 or 75 gallons.
I don't think we have enough information from you to answer the questions properly though.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
