How Are Armature Coils Configured in Synchronous Machines?
Armature coils in synchronous machines can be configured in various ways, including between opposite or adjacent slots. The induced EMF in a coil is derived from the air gap flux linked to the coil, which is determined by the rate of change of magnetic flux through the coil area, as described by Faraday's law. The discussion clarifies that flux linkage occurs only when the magnetic flux passes through the coil area, not merely at its edges. It is emphasized that different coil configurations yielding the same total rate of change of magnetic flux will produce the same induced voltage. Understanding these principles is essential for grasping the operation of synchronous machines and their electromagnetic behavior.
phantom_photon
Hello, I'm a little confused about synchronous machines. Specifically, I don't understand how the armature coils are wound. In discussing how the windings are configured in a three-phase synchronous machine, my textbook provides several diagrams which suggest that the windings of a coil go between opposite slots.
Are all synchronous machines constructed in this way or is it possible to have other configurations of armature windings? For example, could the coils be wound between adjacent slots?
Also, I don't understand the derivation my textbook gives for EMF induced in the coil. It obtains the air gap flux linked per coil by integrating air gap flux density around the interior of the stator from x=0 (x is an arc length co-ordinate fixed with respect to the stator) to x=2*Pi*R/p (R is the stator interior radius, p is the number of rotor poles) and multiplying the result by the axial length of the rotor. The induced EMF is then obtained by application of Faraday's law.
My problem with this derivation is that I don't understand how the air gap flux is linked to the coil. It's possible I have misunderstood the meaning of "flux linkage". I understand it to be equal to:
N\Phi = N\int_A{{\bf B}\cdot{\bf dS}
where N is the number of turns in the coil, \Phi is the flux linked to one turn of the coil, {\bf dS} is a unit vector normal to the plane of the coil and A is the planar surface bounded by the coil. This would mean that air gap flux is only linked (and therefore EMF-inducing) when it flows through the loop of a coil, not when it simply intercepts the edges of a coil as seems to be the case with coils wound between opposite slots. Could somebody please explain this to me?
Your interpretation of flux linkage is correct -- it's only the flux that goes through the coil area that induces the coil voltage. Can you post a link to a picture of the synchronous machine coil arrangement?
Please find attached a diagram of a two-pole, three-phase synchronous machine. In this diagram a', b' and c' are connected to neutral while a, b and c actually represent independent sets of coils distributed around the stator interior. They are connected in series so that the EMF induced in each coil is slightly out of phase with it's neighbour and the voltage for a particular phase is found by summing the EMF phasors of each coil in that phase.
My understanding is that, at the moment captured in the diagram, the flux through coil a-a' wil be zero. However, the rate of change of flux will be greatest at this point hence the induced EMF greatest. If the rotor were to turn a further 90 mechanical degrees the flux linked through coil a-a' would be greatest but it's time derivative would be zero, therefore the induced voltage would be zero. This is what I think my textbook is trying to tell me. Have I understood this correctly?
What confuses me about the flux linkage concept is that I've always imagined the linked flux as being uniformly distributed over the area of a coil (as in a tranformer or inductor) but that's not the case here. The equation for flux linkage indicates that this makes no difference to the flux linked to the coil (and hence the induced EMF) but it seems to me intuitively that it should. If a sinusoidal magnetic flux threads through a coil several meters in diameter would the induced voltage be the same as if the coil were tightly wrapped around an iron core carrying the same flux? Is there some limitation inherent in the derivation of the aforementioned equation that I am unaware of?
It's the dB/dt that generates the output voltage of the coil. Whatever configuration you use to get the same total dB/dt over the coil area, you will get the same V(t) out. Remember that B=mu*H, so that's why motors and electromagnets use ferrous cores. Sounds to me like you have a pretty good understanding of all this!
Whatever configuration you use to get the same total dB/dt over the coil area, you will get the same V(t) out.QUOTE]
Okay, thanks, I guess that makes sense. I'm glad I decided to take an electromagnetics class this year - hopefully I'll have a better knowledge of these things by the end of the course.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
