How are diamonds attached to a diamond drill bit?
  • Thread starter Thread starter olgranpappy
    Bit Diamond Drill
The discussion centers on the methods used to attach diamonds to diamond drill bits, exploring various techniques and processes involved in the manufacturing of these tools. Participants seek to understand both the attachment methods and the overall construction of diamond drill bits.
  • Some participants mention that sintering and electroplating are common methods for attaching diamonds to drill bits.
  • It is noted that diamonds may be powdered and mixed with sintered or powdered metal.
  • One participant inquires about the specifics of how electroplating works with diamonds, questioning whether it is standard to plate non-metals and suggesting a method involving nano-sized diamond clusters.
  • Another participant speculates that sputtering or electroplating could be used to build up the matrix around diamond powder once attached.
  • Chemical vapor deposition (CVD) is mentioned as a common process, with links provided for further reading.
  • A participant introduces the concept of co-deposition, suggesting that diamonds are deposited over the surface rather than implanted, and references a specific technique related to electroplating co-deposition.
Participants express various viewpoints on the methods used to attach diamonds, with no consensus reached on a single process. Multiple competing views and techniques are presented, indicating an unresolved discussion.
Participants reference proprietary processes and specific techniques without providing definitive explanations or universally accepted methods. The discussion includes assumptions about the effectiveness and standardization of the mentioned techniques.
olgranpappy
Homework Helper
Does anyone know how the diamonds in a diamond drill bit are attached to the drill? I tried google but didn't find much help regarding this question. I did find a picture of a diamond tipped drill:
http://www.diamond-drill-bit-and-tool.com/Diamond-Drill/MAIN.htm
But no explanation of how the diamonds are made to stick to the drill. Or how the drill is made. Anyone have a detailed (or not so detailed) explanation of how this works?
Cheers,
Adam
Manufacturers usually come up with some proprietary name for their process (for trademark), but in my experience, sintering and electroplating are the most common methods.
Often the diamonds are powdered and included with sintered or powdered metal.
Thanks for the answer.
Could you say a little more about how electroplating works with diamond? The examples that I have seen of electroplating usually involve plating one metal with another metal. Is it a standard process to plate metal with non-metal?
For diamonds, does the electroplating process work by first putting a charge on nano-sized diamond clusters and then using a current to deposit the clusters on the metal, or some other way? Thanks,
Adam
Just a guess, but I think sputtering or electroplating would be the method to build-up the matrix around the dimond powder once it was attached.
I think the Diamonds are not implanted but they are deposited over the surface. Have heard about co-deposition technique?
I think that can be quite a good option
In the Electroplating Co-Deposition Tech., the diamond grains are co deposited over the substrate material
Do visit this link http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TVV-4MYF5WD-1&_user=10&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=2b40da4c21a8d6e684b30dd4da359eb9"
Thank You​
10K
