Spotting Similar Triangles: Comparing ASA, SSS, SAS, and RHS Methods
  • Thread starter Thread starter thomas49th
To determine if triangles are similar, it is sufficient to establish that two pairs of corresponding angles are congruent, which can be derived from the properties of parallel lines and transversals. The methods ASA, SSS, SAS, and RHS are primarily used to prove triangle congruence, not similarity. The Angle-Angle (AA) criterion is the key for establishing similarity, as it ensures that the third angle is also congruent due to the triangle's angle sum property. The discussion highlights the importance of recognizing congruent angles formed by parallel lines intersected by a transversal. Understanding these concepts clarifies the distinction between triangle similarity and congruence.
thomas49th
I solved both questions, but how do I know that the triangle were similar, I am guessing it's somthing to do with the parallel lines...
ASA
SSS
SAS
RHS
^ I thought these were the ways to spot similar triangles...
It's been a long time since I came across those abbreviations, and I don't remember most of it. But you can see that AB and AC are transversals intersecting the parallel lines. Thus angles ADE = ABC and and angles AED = ACB. And, of course, angle A is common to both.
Edit: I now recollect... Angle-Side-Angle, Side-Side-Side... :)
and DAE = BAC and AEC = BAC
so is it AAA -- is there such a similar/congrucy thingy ma jig?
ASA, SAS, SSS, etc, aren't to find that triangles are *similar* - they are for showing the triangles are *congruent* (same size)
To know the triangles are similar, you only need to know that two of the corresponding pairs of angles are congruent (because it follows that since the sum of the angles in a triangle is 180 degrees, the 3rd pair of corresponding angles would also have to be congruent.) Thus, AA is all that's needed for *similar* triangles.
Obviously, angle A is congruent to angle A (reflexive property)
You can do either or both of the other pair of corresponding angles just as you mentioned - it has to do with the parallel lines. "When a pair of parallel lines are cut by a transversal, the corresonding angles are congruent."
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
