How big is the path of an IR emitter
  • Thread starter Thread starter MartinJH
    Ir Path
The discussion centers on the signal path of an infrared (IR) emitter used in remote controls. When a button is pressed, the IR signal typically emits from the LED in a cone shape, with a divergence angle of a few degrees, often extending to several tens of degrees. Observations through a mobile phone camera confirm the flashing of the IR LED. Additionally, IR signals can be reflected by walls and furniture, which can help trigger the receiver even when not in direct line of sight. Understanding this can enhance the effectiveness of using remotes from various positions.
MartinJH
This is a very silly question but anyway.
When using a remote for a TV or digital channel receiver, how big is the path/signal emitted from the remote when a button is pushed.
Will it come from a point, thee emitter, and form a cone shape until its picked up by the receiver.
its a dull question, I know. :)
From what I found, most IR LEDs emit into a divergence angle of a few degrees.
If you look at it through your mobile phone camera, you'll see it flashing. (...Looking...) Hmm, I'd say it's more like few 10's of degrees. Also IR is reflected well by the walls and furniture, often this reflected light is sufficient to trigger the receiver.
Thank you.
I always use that method when in bed or not in direct path to the TV :) lol.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
