How calculate iris radius and cavity radius in accelerator?
To calculate the iris radius, cavity radius, and disk thickness in linear accelerators with a disk-loaded structure, one must consider the wavelength of operation. Numerical simulations are essential for optimizing these parameters to achieve optimal performance. The literature provides extensive details on the calculations and methodologies involved. It is crucial to ensure clarity in the simulation process and parameter adjustments. Proper understanding and application of these principles lead to improved accelerator design.
Ryan Reed
In linear accelerators that use a disk loaded structure (traveling wave), how would you calculate the iris(disk hole) radius, cavity radius, and disk thickness according to the wavelength
You make a numerical simulation and optimize the parameters until you get the best results.
You can find more details in the literature. Is something there unclear?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
