How can I calculate forces on a vehicle frame?
To calculate the forces on a vehicle frame for an SAE Baja vehicle, it's essential to estimate the impact forces based on the vehicle's weight of 500lbs and a top speed of 30mph. Understanding the impulse or time of impact is crucial, as it varies with collision type and location, particularly where bumpers and shock absorbers are located. A back-of-envelope calculation can model the impact as a spring contact, which simplifies the analysis if actual springs are used. If not, the rigidity of the frame's bending and flexing must be considered. Ultimately, the kinetic energy from an impact must be absorbed by the vehicle's springs.
7055
I am working on an SAE Baja vehicle for a competition as part of my coursework requirements. Right now I am trying to come up with a method to estimate the forces that the frame will be subjected to. I need help doing this. I know that the top speed will be 30mph and that the vehicle will weigh 500lbs. To calculate the force of an impact I would also need to know the impulse or time of impact. I'm kind of stumped on where to start.
Impulse time depends on the type of collisions and where it strikes - you presumably have bumpers and shock absorbers at strategic places?
A back-of-envelope approach would model the impact as a spring contact ... if you have actual springs then this should be easy otherwise you have to work something for the rigid frame bending/flexing. If the idea is to figure out what sort of shock-absorbers to include then you can just put in the spring constant (or however the absorbers get rated) as a variable in the calculation.
The kinetic energy of the impact has to be absorbed by the springs.
