How Can I Determine Elevation Based on Changes in Air Pressure?
The discussion focuses on determining elevation based on changes in air pressure using a pressure sensor and static reference pressure. The user has a pressure value of 102 kPa at ground level and measures a pressure of 101 kPa at an unknown height. They seek a formula to calculate elevation from pressure, noting that existing formulas typically solve for pressure rather than height. A simplified iterative method is proposed, but it is inefficient and slow, prompting the need for a more accurate calculation method.
  • Understanding of basic atmospheric pressure principles
  • Familiarity with pressure sensors and their applications
  • Knowledge of the barometric formula for pressure and altitude
  • Basic programming skills for implementing iterative calculations
  • Research the barometric formula for altitude calculation from pressure
  • Explore the use of the Ideal Gas Law in atmospheric calculations
  • Learn about the impact of temperature on pressure and altitude relationships
  • Investigate optimization techniques for iterative algorithms in programming
Engineers, meteorologists, and hobbyists involved in atmospheric science, as well as developers working with pressure sensors and altitude measurement systems.
TechSpec
Air pressure and height...
Ok, i have a hard time with the air pressure. I should do a calculation with the pressure and determine the height.
I have a pressure sensor which i use for pitot-tube sensing and i have a static sensor of the same kind to measure static reference pressure. I can determine speed with the given values of temperature and pressure differency. But i should also calculate a height where that pitot-tube sensor is. I have a pressure value from the ground level and i use that as a reference value for the height calculation. However, i did find some formulas to calculate the pressure from the given height, but not vice versa.
The basic principle would be like this:
Lets assume that I am in a certain level from a sealevel, that height is unknown but let's say its within few hundred meters.
I have the air pressure of 102kPa and i move upwards into a point where the air pressure is 101kPa, now the big question is, how much is the elevation in meters? The height from a sealevel is not important and not even known, only thing matters is how much i elevated from point A to B. Is that possible to determine with only temperature and a reference pressure and a current pressure which is altered by height? The accuracy also is not critical, let's say we don't take count the gravity changes or climate pressure changes during the measurements. Only temperature and pressure.
TechSpec
Here's a two stage formula for pressure versus altitude (I can't remember what the default temperature at sea level was, maybe 70 degrees farenheight). There's a third stage for very high altitudes ( spacecraft and weather balloons would need this), but I didn't have this in my archive of various junk.
dAlt = altitude in feet.
dPressure is pressure in psi.
Code:
    if(dAlt < 36089.24)
        dPressure = 14.7*pow(1-6.8755856E-6*dAlt, 5.2558797);
    else
        dPressure = 14.7*.2233609*exp(-4.806346E-5*(dAlt-36089.24));
True, but...
That is the formula i found too, but it solves the pressure, not the height. And i have no method of opening that formula to solve the height with a given pressure..
so i made this really really really stupid method of doing it and it is highly simplified, but you can see the principle.for(i=0;i<counts;i++)
altitude=1; .......// start from the lowest alt
pressure=calculate_pressure(altitude);...// count the pressure
if(pressure == sensor_output)...// must have tolerance !
return altitude;
else
altitude++;
if (counts > 10000).......// too high altitude
return error;
It might work but its very slow method and i HATE to do it like that..
So if i could calculate it the correct way i would save a lot of time, and get the accuracy.
TechSpec
  • · Replies 27 ·
  • · Replies 50 ·
  • · Replies 67 ·
22K
  • · Replies 48 ·
