How can i find 0.13r(as in the 3 recurring) as a fraction
  • Thread starter Thread starter harlatt
    Fraction
To convert the repeating decimal 0.1333... into a fraction, it can be expressed as the sum of 0.1 and 0.0333..., where 0.1 equals 1/10 and 0.0333... equals 1/30. The next step is to add these fractions together, which requires finding a common denominator. The correct addition leads to the fraction 1/10 + 1/30, which simplifies to 4/30 or 2/15. Thus, 0.1333... as a fraction is 2/15.
harlatt
How can I find 0.13r(as in the 3 recurring) as a fraction
Can anyone give me an idea of how I can find 0.13 as a fraction?
:rolleyes:
think of 0.133r as 0.1 + 0.033333r... and then add the fractions together.
Hi there harlatt and welcome to PF,
From wikipedia:
Wikipedia said:
A shortcut in converting a repeating decimal to a fraction
If the repeating decimal is between 0.1 and 1, and the repeating block is n digits long occurring right at the decimal point, then the fraction (not necessarily reduced) will be the n-digit block over n digits of 9. For example,
* 0.444444... = 4/9 since the repeating block is 4 (a 1-digit block),
* 0.565656... = 56/99 since the repeating block is 56 (a 2-digit block),
* 0.789789... = 789/999 since the repeating block is 789 (a 3-digit block), etc.
If the repeating decimal is between 0 and 0.1, and the repeating n-digit block is preceded only by k digits of 0 (all of which are to the right of the decimal point), then the fraction (not necessarily reduced) will be the n-digit block over the integer consists of n digits of 9 followed by k digits of 0. For example,
* 0.000444... = 4/9000 since the repeating block is 4 and this block is preceded by 3 zeros,
* 0.005656... = 56/9900 since the repeating block is 56 and it is preceded by 2 zeros,
* 0.0789789... = 789/9990 since the repeating block is 789 and it is preceded by 1 zero.
For any repeating decimal not perscribed above, it can be written as a sum of a terminating decimal and a repeating decimal of one of the two above types. For example,
* 1.23444... = 1.23 + 0.00444... = 123/100 + 4/900 = 1107/900 + 4/900 = 1111/900
* 0.3789789 ... = 0.3 + 0.0789789... = 3/10 + 789/9990 = 2997/9990 + 789/9990 = 3786/9990 = 631/1665
The whole document can be found here: http://en.wikipedia.org/wiki/Recurring_decimal
Hope this helps:smile:
:eek: :eek: :eek: :eek: :eek:
Sorry but i rlly don't get none of it lol
ohhhhhh i get it! cheers thanks sooo much!
wud it be 3/19 or is tht completely rong
its not 3/19, but what was your work that got you there, maybe we can point out an error.
Nope, not quite.
erm...
to be honest i don't get it now :(
im gettin rlly stressed cos I've been on this question for bout an hour nd have no clue
so the numbe .1333 can easily be divided into 0.1 and 0.033333
.1 is easy as 1/10
but using hootenannny's post what would 0.03333333333 in fraction form?
is it 15/90?
harlatt said:
erm...
Okay, so we have the decimal 0.1\dot{3}; this can be split into two decimals thus;
0.1\dot{3} = 0.1 + 0.0\dot{3}
Now, can you write 0.1 and 0.0\dot{3} as fractions?
harlatt said:
is it 15/90?
No, but very very close.
is the whole answer 15/90 I've gone thru what the wikipedia thing has?
erm..... illl try agen one sec
The answer is not 15/90. Try doing what was suggested above and show your work
nope I am still gettin 15/90
i went
0.133333...= 0.1 + 0.033333
=1/10 + 3/90 = 12/90 + 3/90 = 15/90
where am i goin rong?
No, try thinking of what 0.333... is as a fraction, then work out the relationship between that and 0.0333...
i don't rlly no
You're nearly there, you just need to add the fractions 1/10 and 3/90 together properly, 1/10 shouldn't become 12/90.
:frown: :frown: :frown:
rlly don't get that, got to go bed now,
shud have come on earlier :(
harlatt said:
i don't rlly no
Are you saying that you don't know what 0.\dot{3} is as a fraction?
yh but i was plusin the 2 factions i.e 10 goes into 90 9 times so i times tht by the one nd add it to the 3
0.3 as a fraction = 3/10 aint it?
comon I've got to go bed :(
:( gtg sorri ill wait for one more reply but anymore ill get shouted at
I meant what is 0.33333333... as a fraction, note the dot above the 3 to denote the recurrence.
Is it 3/9?
harlatt said:
Is it 3/9?
Yes, which simplifies to 1/3. But you don't want 0.33333, you want 0.0333333; so what is 0.033333 as a fraction?
is it 1/30?
  • #31
harlatt said:
is it 1/30?
Spot on. Now, RE one of my previous posts
So, we now know that 0.1 = 1/20 and 0.03333 = 1/30, thus;
0.1\dot{3} = 0.1 + 0.0\dot{3} = \frac{1}{10} + \frac{1}{30} = ?
Can you go from here?
  • #32
quick I am being shotued at now :( sorri to be a pain
  • #33
is it 4/30?
  • #34
no i think is 3/30
  • #35
harlatt said:
is it 4/30?
Yes, which simplifies to...
  • #36
sorri to rush you but can u please be quick?
  • #37
erm is it 1/10?
  • #38
harlatt said:
erm is it 1/10?
No, you need to find a common factor between 4 and 30.
  • #39
what? sorri
  • #40
ive got to go now :( thanks for the help ill have to work on it more tomorrow willl u be on tomorrow?
  • #41
harlatt said:
what? sorri
You need to find a number that divides perfectly into both 4 and 30. For example, a common factor of 6 and 4 is two. Since when you divide 6 by 2 you obtain 3 and when you divide 4 by 2 you obtain 2.
  • #42
No problem. Possibly, but if I'm not on someone else will gladly help you.
  • #43
And show what you are doing- don't just toss out numbers.
