How can I graph this equation (Rayleigh Plesset for sonoluminescence)?
  • Context: Graduate
  • Thread starter Thread starter Flaneuse
    Graph Sonoluminescence
The discussion revolves around graphing the Rayleigh Plesset equation as it pertains to sonoluminescence. Participants explore methods for visualizing the relationship between the radius (R) and time (t) while considering the equation's parameters and constants.
  • Homework-related
  • One participant presents the Rayleigh Plesset equation and seeks guidance on graphing it while treating certain variables as constants.
  • Another participant questions the nature of P(t), asking if it needs to be expressed in terms of another equation before plotting.
  • A different participant suggests that to plot R vs. t, the equation must be solved numerically, recommending the Euler method despite its limitations with non-linear differential equations.
  • This participant also mentions using Wolfram Alpha for numerical solutions but notes potential difficulties in input interpretation and suggests Mathematica as an alternative.
  • A later reply indicates that the original poster has attempted to use Wolfram Alpha but encountered issues, expressing a need to either find Mathematica or solve the equation independently.
Participants do not reach a consensus on how to graph the equation, with differing views on the necessity of solving the equation numerically and the interpretation of P(t).
There are unresolved questions regarding the definition and role of P(t) in the equation, as well as the challenges associated with numerically solving the Rayleigh Plesset equation, particularly in the context of using various software tools.
Individuals interested in numerical methods for solving differential equations, particularly in the context of fluid dynamics and sonoluminescence, may find this discussion relevant.
Flaneuse
The following is the Rayleigh Plesset equation, modified so as to be specific to the phenomenon of sonoluminescence.
R\ddot{R} + 3/2(\dot{R}^2 = (1/ρ) (p_{g} - P_{0} -P(t) - 4η (\dot{R}/R) - (2γ/R))
I'm trying to graph this for comparison of maxima and minima (of R) with another graph. If everything except R (and time derivatives of R) and P(t) are constants, how can I do this? (in Excel or an online program, for example; there is no need for actual solving of the problem if it can be graphed without doing so.)
Mathematics news on Phys.org
Dude what is this P(t)? Is it any other equation or we have to make it as a subject like P(t)= something and plot it?
To plot R vs. t you are going to have to solve the equation, at very least numerically. The simplest method for numerically solving equations is the Euler method, but it's also the least accurate and it probably doesn't work too well with non-linear differential equations. A decent numerical solution will probably be hard to calculate using Excel. The online website I know of that will solve DEs is www.wolframalpha.com. If you know all of your numbers and the function P(t), along with your initial conditions, then you might be able to get the site to plot it, though sometimes getting the site to interpret your input correctly can be tricky, so if you have access to Mathematica (which the program that wolframalpha runs off), then you can also use that to solve the equation numerically.
I tried Wolfram Alpha already, but it seemed to interpet what I was asking rather strangely; of course, it is quite possible that the way I typed it was less than perfect... I guess I'll have to either find a way to get Mathematica or solve it on my own. Thanks though!
  • · Replies 0 ·
