How can i prove that a multiple of 4 is a multiple of 12?
  • Thread starter Thread starter Link
    Multiple
A multiple of 4 is not necessarily a multiple of 12, as demonstrated by the example of 8, which is a multiple of 4 but not of 12. The discussion clarifies that while multiples of 4 can include numbers like 8, 16, and 20, these do not meet the criteria for multiples of 12. Conversely, it is established that every multiple of 12 is indeed a multiple of 4, since 12 can be factored into 4 and 3. This relationship is confirmed through the equation showing that if x is a multiple of 12, it can be expressed as 4 times another integer. Therefore, the assertion that a multiple of 4 is a multiple of 12 is incorrect.
Link
You can't ... because it's NOT true.
Example:
(2)*(4)=(8) is NOT a {Multiple of (12)}
However, you can prove that a {Multiple of (12)} is a {Multiple of (4)}. Begin by factoring (12):
(12) = (4)*(3)
Now consider the integer "k" multiple of (12) given by (12)*k, where {k = 1, 2, 3, ...}:
{"k" Multiple of (12)} = (12)*k = {(4)*(3)}*k = (4)*{(3)*k} = (4)*m
where "m" is a positive integer. Thus:
{Multiple of (12)} IS A {Multiple of (4)}
It is true that a multiple of 12 is a multiple of 4- just the opposite of the original post. That's true because "multiple of 12" MEANS "12 times some integer". If x is a multiple of 12, then x= 12n for some integer n. "Multiple of 4" MEANS "4 times some integer". Of course, if x is a multiple of 12 then x= 12n= 4(3n) so that x is 4 times the integer 3n: a multiple of 4.
