How can i receive Bluetooth signal in tiny robot ?
The discussion centers on how to enable a small robot to receive Bluetooth signals from a cell phone for control purposes. Participants explore various techniques, components, and design considerations relevant to this application.
  • One participant suggests using an Arduino Bluetooth shield or an old cell phone as a receiver for the robot.
  • Another participant mentions that Arduino has been successfully used to receive Bluetooth signals for various outputs, referencing a specific website for guidance.
  • A different approach proposed involves using a radio modem and a pager to control the robot via Bluetooth.
  • One participant outlines several options, including using a Bluetooth module integrated into the robot, employing a microcontroller like Arduino with a Bluetooth module, or utilizing a dedicated wireless receiver for Bluetooth signals.
  • It is noted that the choice of technique should depend on the specific design and capabilities of the robot, emphasizing the importance of research and planning.
Participants present multiple competing views on the best approach to receive Bluetooth signals in a tiny robot, and the discussion remains unresolved regarding which method is superior.
Participants do not specify the limitations of their proposed methods, such as potential compatibility issues, range limitations, or power requirements of the components mentioned.
This discussion may be useful for hobbyists, robotics enthusiasts, and individuals interested in integrating Bluetooth technology into small robotic projects.
error 401
hi
i want to to create a small robot controlled by Bluetooth of cell phone but i wondered about how the robot can receive this signal ? what is the technique i should use in my tiny robot so i can control it ?
I think the Arduino family has a bluetooth "shield", or you might consider just using an old cell-phone as the robot receiver as well. Look at hackaday.com for pages of information about how to hack bluetooth into stuff.
Try a radio modem and use a simple pager to operate your little robot via Bluetooth.
There are a few different techniques you can use to receive a Bluetooth signal in a tiny robot. One option is to use a Bluetooth module, which is a small electronic component that can be integrated into your robot's design. This module will allow your robot to communicate with other devices, such as a cell phone, via Bluetooth.
Another option is to use a microcontroller, such as an Arduino, which can also be equipped with a Bluetooth module. The microcontroller can receive the Bluetooth signal and then control the movement or actions of your tiny robot.
You could also consider using a wireless receiver that is specifically designed for receiving Bluetooth signals. This would eliminate the need for a separate module or microcontroller, making the design of your tiny robot simpler.
Ultimately, the technique you choose will depend on the specific capabilities and design of your tiny robot. It's important to carefully research and plan out your design to ensure that the Bluetooth signal can be received and utilized effectively.
