How can I show that the bulk modulus is about r^-4?
The discussion focuses on demonstrating that the bulk modulus is approximately proportional to r^-4. Participants express confusion about the starting point for the solution and the necessary equations. There is a request for clarification on the values of m and n, as well as the pair potential discussed in class. Additionally, the relationship between r and Ω is questioned, indicating its relevance to the problem. Overall, the thread highlights the challenges faced in deriving the bulk modulus from the given equations.
joemmonster
Using the equations, show the bulk modulus is about r^-4.
Tried to plug Uij but it is not same as U. To be honest, I don't know where to start.
What values were you given for ##m## and ##n##? If you weren't given values, what pair potential have you discussed in class?
What's the relationship between ##r## and ##\Omega##?
