How can I solve the Hamilton-Jacobi equation for this time-dependent potential?
  • Thread starter Thread starter dipole
dipole
I'm given the time-dependent potential,
V(x,t) = -mAxe^{-\gamma t}
and asked to find the solution to the Hamilton-Jacobi equation,
H(x,\frac{\partial S}{\partial x}) + \frac{ \partial S}{\partial t} = 0
Without any additional information, I'm assuming the correct Hamiltonian is given simply by,
H = \frac{p^2}{2m} -mAxe^{-\gamma t}
which gives me,
\frac{1}{2m}\bigg ( \frac{\partial S}{\partial x} \bigg )^2 - mAxe^{-\gamma t} + \frac{ \partial S}{\partial t} = 0
but I'm having troule separating the variables in order to solve this equation. Normally, when V = V(x) you can use the form S(x,\alpha,t) = W(x,\alpha) - Et, but here this won't work.
Have I somehow used the wrong Hamiltonian, or do I just need to guess correctly the right form of S?
I suggest using the method of characteristics to solve this PDE problem.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
