How can i use 5V to switch 24V on/off?
  • Thread starter Thread starter opmal7
    Switch
A user is seeking advice on using a 5V joystick button to control a 24V motor brake in a project involving a motor with a built-in brake. The button currently functions as a dead man's switch, and the user wants it to also disengage the brake. A relay is suggested as the solution to switch the 24V output using the 5V input from the joystick. The discussion emphasizes the simplicity of wiring a relay for this purpose, noting the importance of preventing motor movement while the brake is engaged. Overall, the conversation highlights the feasibility of integrating a relay to achieve the desired functionality.
opmal7
I'm working on a project that uses a joystick to control a motor. The motor has an electric motor brake built in, and I want to be able to engage/disengage the brake with a button on my joystick.
The motor runs on 24VDC, and the joystick runs on 5VDC. I currently have the button on the joystick configured as a dead man's switch for the motor (button has to be pressed to move the motor), and I would like to have the same button disengage the motor brake.
I'm not real familiar with relays or other electronic equipment. Is there a device that I can wire the 5V button to as input, and have 24V as output to the motor brake?
Thanks in advance for any suggestion/info.
Yes: it's called a relay.
Looks like you are about to become familiar then.
Go to an electrical suppliers and say "I want a relay to switch 24V from 5V".
They'll ask if you want normally open or normally closed (I guess you want open).
They'll give you one.
How did you rig the dead-mans-switch?
Sounds like you have a single-pole button and you want it to do two tasks.
Thanks for the info. I'll see what I can find in 5V to 24V relays.
The push-button is wired into the motor controller as a digital input. The motor controller's software allows me to configure the digital input as a dead-man's switch. Your correct saying I want the single-pole button to have 2 functions. The motor brake is engaged when the motor is not moving to prevent back-driving. Pushing the button releases the motor brake and allows the motor to move. This will prevent someone from trying to move the motor while the brake is engaged which would push a lot of current to the brake or apply a lot of torque and possibly cause it to fail.
Again, thanks for the info.
I don't really understand your project. But I think you want to drive 24V from 5VDC. It's not difficult. You only need one 5V relay to control 24 motor. If you will, I can show you how to wire the circuit. It's not difficult. Take it easy.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
