How did this second-order initial value problem do this?
myusernameis
Find a second-order initial-value problem whose solution is sin at
so i know that
y' = a cos at
y" = -a^2 sin at
but the solution says that
"Then y(t) = sin at is
a solution to 2 y ''+ a y = 0 . Our initial conditions must be y(0) = 0, y '(0) = a ."
how do i know that it's 2y'' + a y? how come it couldn't be something else like y''+y'+ y?
thanks
This is because y"+y=0 is the only DE that has the solution of the form Acos kt + Bsin kt, other DE's have a solution of the form Ae^{bt}+... such as the one you posted. (y"+y'+y). This stems from the characteristic equation r^{2}+r=0 which has complex roots...
That can't be right; y(t)=\sin(at) is not the solution to that DE, y(t)=\sqrt{2a}\sin(\sqrt{\frac{a}{2}}t)<br /> is.
Either you've made a typo/error, or the solution manual has a typo/error or some combination of the two.
thanks
Well, as you've found, if y(t)=\sin(at), then y&#039;(t)=a\cos(at) which is orthogonal to both y(t) and y''(t) (you can't add some non-zero multiple of cos(at) to some polynomial of sin(at) and get a constant or zero), so the DE can't contain a y'(t) term...
Yes, if y= sin(at), then y'= -a cos(at) and y"= -a2sin(at).
The simplest second order differential equation y= sin(at) satisfies is y"+ a2y= 0. I don't know where you got that "2".
(I wouldn't be surprised if this were the answer to "problem 2"!)
thanks!
turns out there wasn't a "2" anywhere...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
