How do astronomers use photodectors
  • Thread starter Thread starter a.a
Astronomers utilize photodetectors, primarily charge-coupled devices (CCDs), in NASA's Hubble Space Telescope to capture high-resolution images of galaxies. The HST's instruments include various types of photodetectors, such as CCDs and a CMOS chip used in the Near Infrared Camera and Multi-Object Spectrometer (NICMOS). An earlier instrument, the Faint Object Camera (FOC), employed an intensified TV tube before being replaced. These photodetectors convert incoming light into electronic signals, enabling detailed analysis of celestial objects. Understanding the functionality of these devices is crucial for grasping how Hubble produces its stunning galactic images.
a.a
How do astronomers use photodectors on nasa's Hubble space telescope to produce galactic images?
I can't find any relevant resourses on the topic.. not on the internet either.
I think the HST just uses CCD's. You can check out how they work.
The current instruments are here http://www.stsci.edu/hst/HST_overview/instruments
Most are CCDs, NICMOS uses a CMOS chip like the one in your digital camera and one of the earlier now repalced instruments FOC used an intensified TV tube.
