How Do I Build a 10-LED Light String with 5W Hyper Violet LEDs?
  • Thread starter Thread starter newhavenhydro
    Build Led Light
To build a 10-LED light string using 5W hyper violet LEDs, a basic understanding of electronics is essential, particularly the relationship between voltage, current, and resistance. The LEDs require a forward voltage of 6-7V and a current of 700mA, which means careful consideration of the power source is necessary. Using a 72V driver is risky due to safety voltage limits; instead, a lower voltage power supply with individual current limiting resistors for each LED is recommended for safety and reliability. It's crucial to ensure that the LEDs are closely matched if they are to be connected in series. Overall, prioritizing safety and proper configuration will enhance the learning experience while building the LED light string.
newhavenhydro
Hi,
I am new to this site, but it seem like there are some very intelligent people posting on this forum and I was hoping someone could help me out.
I am trying to build a LED light.
I would like to string 10 of these lights together and plug them into the wall.
5 watt
430nm (hyper violet)
6-7 max forward voltage
700mA
1000-1200 mW radiant power (not sure if that matters)
http://www.aliexpress.com/store/product/Hyper-Violet-5W-430nm-High-Power-LED-for-Plant-Growing-and-Aquarium/804169_1447691205.html
I am confused on what parts i need and the logic/science behind how the volts amps and watts work. i am really here to learn i hope someone can help.
newhavenhydro said:
Hi,
5 watt
700mA
Welcome to the PF.
Your question is quite broad, so it is difficult for us to give a simple answer. If you don't yet know basic V=IR type electronics, it will be a big task for us to coach you through this. What background do you have in electronics so far?
From your link: "Voltage: 6.0-7.0V Current: 700mA" -- What are you planning to use for your power source?
Here is a link with basic info about driving LEDs: http://www.ledsmagazine.com/articles/print/volume-4/issue-8/features/driving-led-lamps-some-simple-design-guidelines.html
I think i am going to use either a 72 volt 700mA 50 watt driver...if i can find one. or 2 36 volt 700mA 25 watt drivers... and though my prior knowledge is pretty lacking i have been studying up a lot... i understand that volts = amps * resistanse... in my readings i believe i will string negative end of the first star to the driver and the positive end of that same star to the negative end of the next star and so on until the tenth light where the wire from the positive goes back to the driver. then the driver gets spliced directly to a three prong AC adapter...
how does that sound...
Only closely matched LEDs can be driven in series. Do you know if those units are matched well enough that they can be driven in series? It should say on the datasheet, or you can call their technical support folks to ask.
Also, 72V is over what is called SELV (safety extra low voltage). You are getting into dangerous/hazardous voltage ranges there. If you can keep the voltages under 60V, you will generally be in the SELV range. But using more like a 12V power supply and putting the LEDs in parallel with their own individual current limiting resistors would be a much safer way for you to go at this point in your learning...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
