How do I correctly derive the formula d = vt + 1/2 at^2?
  • Thread starter Thread starter anandzoom
    Derivation Motion
The discussion focuses on deriving the formula d = vt + 1/2at^2, addressing the initial misunderstanding about incorporating initial velocity in the derivation. Participants clarify that the formula can be derived using both calculus and algebra, emphasizing the relationship between displacement, velocity, and acceleration. The importance of understanding average velocity and the area under the velocity-time curve is highlighted, with references to calculus concepts. A step-by-step breakdown is provided to show how the formula is constructed from basic principles. Ultimately, the correct derivation confirms the relationship between distance, initial velocity, and acceleration over time.
anandzoom
d=vt+1/2at^2
Derive me this formula please... When I do I get 1/2(vt+at^2)...i know that I'm doing a mistake by not considering the initial velocity... So how do I correct it?
anandzoom said:
d=vt+1/2at^2
Welcome to the PF.
Can you show us the steps of your derivation? That will help us find any errors.
Welcome to the PF.
v=d/t ;d=vt
a=d/t^2 ;d=at^2
1/2d+1/2d=1/2vt+1/2at^2
d=1/2(vt+at^2)
anandzoom said:
v=d/t ;d=vt
a=d/t^2 ;d=at^2
d=1/2(vt+at^2)
Thank you, that helps. Have you had any Calculus yet? Are you familiar with derivatives?
Yup
anandzoom said:
Yup
Great. In that case, where did the bolded equation come from below?
anandzoom said:
v=d/t ;d=vt
a=d/t^2 ;d=at^2
d=1/2(vt+at^2)
acceleration= velocity/time
Actually it's the change in velocity over time, or in calculus, a(t) = dv(t)/dt.
But it's also possible to do the derivation for a constant acceleration using only triangles. Here's a YouTube video that helps to explain it:
:smile:
How can you say that displacement is area under the velocity curve?
That's from calculus:
v(t) = dx(t)/dt
a(t) = dv(t)/dt
So when you integrate both sides of the first equation, you are effectively finding the "area under the curve"...
x = \int{v(t) dt}
Ok thanks
If acceleration is constant, then you can use algebra instead of calculus. Note that Δt means change in time, Δx means change in position, a = acceleration, v = velocity.
initial velocity = v
final velocity = v + a Δt
average velocity = (initial velocity + final velocity) / 2 = ((v) + (v a Δt))/2 = v + 1/2 a Δt
Δx = average velocity Δt = (v + 1/2 a Δt) Δt = v Δt + 1/2 a Δt^2
Likes berkeman
it is not possible to write v = d/t but v=dx/dt and a = dv/dt
then v(t) =∫a(t)dt =at + v , v is the initial velocity and the acceleration a is constant.
it comes : x(t) =∫v(t)dt = 1/2 at^2 + vt + x(0), x(0) is the initial position assumed nill then x(0) =0
finally the distance d is x(t) =d= vt + 1/2 a t^2
Likes berkeman
