How do I determine if a given set of vectors can generate a vector space?
Shackleford
How do I show the vectors, polynomials, and matrices generate the given sets?
A subset of a vector space generates the vector space if the span of the subset is the vector space. The span is the set of all linear combinations.
For 6, do I show the vector are linearly independent and can thus generate F3? I assume this is simply R3. What about for 6 and 8?
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20110608_203711.jpg
For #6: What is the span of {(1,1,0),(1,0,1),(0,1,1)}?
does there exist an a,b,c such that
a(1,1,0) + b(1,0,1) + c(0,1,1) = (x,y,z)
for all vectors (x,y,z) in F^3?
tylerc1991 said:
For #6: What is the span of {(1,1,0),(1,0,1),(0,1,1)} ?
I'm assuming they're linearly independent. If so, then it's R3.
I don't see why there couldn't be.
a + b = x
a + c = y
b + c = z
a + b = x
a + c = y
b + c = z
But what are the specific a,b, and c given an x,y, and z?
a = (1/2)(x + y - z)
b = (1/2)(x - y + z)
c = (1/2)(-x + y + z)
Shackleford said:
a = (1/2)(a + b - c)
b = (1/2)(a - b + c)
c = (1/2)(- a + b + c)
I am getting the same thing, only with the a,b, and c replaced by x,y, and z respectively :biggrin:.
OK so you have shown that any vector in F^3 can be represented by a linear combination of (1,1,0),(1,0,1), and (0,1,1). Thus span{(1,1,0),(1,0,1),(0,1,1)} = F^3.
Also, F^3 does not equal R^3. F is a general representation of a field.
Oops. I fixed it. This result seems trivial. That's why I was confused. What's a case in which you could not represent any arbitrary vector in F3 as a linear combination? If there were only two given vectors...
Right, if the only vectors given were (1,1,0) and (0,0,1), then we could not represent (3,2,1) for instance.
Or if we were given three vectors with one being relatively linearly dependent. How would that show up in determining the coefficients? Some impossible relationship? Or some common relationship?
You have to show that the given set of vectors spans the given vector space.
For instance, the set of vectors {(0,0,1)(0,1,0)(1,0,0)(1,1,1)} generate R^3, but they are not linearly independent.
The set of vectors {(0,1,1),(1,0,0)} are linearly independent but they do not span R^3.
I guess that's where I'm fuzzy. The only time a given set of vectors will not span a vector space is in a case where it's too small, i.e. not enough vectors.
