How do I express delta as a function of epsilon in epsilon-delta proofs?
  • Thread starter Thread starter Laura1321412
    Proof
Laura1321412
Im having trouble with epsilon -delta proofs in general... I keep looking at lots of examples I am just having trouble figuring what steps to take first. My question is the lim (x,y) -- > (0,0) of x^4-y^4/ x^2+ y^2
I understand the definition of the epsilon delta proofs, i just can't wrap my brain around what to do!
Not much. I know i can figure out |x^4|/ x^2 +0 = |x| <= e , and then the same for the y component ... But I am not really sure why you can just let y or x =0 ? Super confused...
You need to show that for any value \varepsilon&gt;0 there is a \delta such that when the distance between (x,y) and (0,0) is smaller than \delta the value of
|x^4-y^4/ x^2+ y^2| is smaller than \varepsilon.
Any suggestion on how i should start?
How about factorising the numerator?
okay,,,
so i did
(x^2 +y ^2 ) (x^2 - y ^2) and cancelled,
so |x+y||x-y| < e
am i able to put delta, as e/|x-y| , or can i only bring real numbers back and forth between the inequality signs?
Your question is now:
"My question is the lim (x,y) -- > (0,0) of x^2-y^2 "
You cannot use x and y to express delta.
Whatever epsilon I give you, you need to be able to give me some delta so that whenever the distance between (x,y) and (0,0) is smaller than delta the distance between x^2-y^2 and the limit L, is smaller than epsilon. So, you better express delta as a function of epsilon, that way you will have an answer for any epsilon I might give you.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
