How do i find minimum for this potential?
  • Thread starter Thread starter wormhole
    Minimum Potential
9 replies · 3K views
wormhole
how do i find minimum for this potential:
u(r)=L^2/2*m*r^2 - b*exp(-ar)/r ?
b,a - constants
L - angular momentum
m - mass
u`(r)=L^2/m+b*exp(-ar)*r(a*r-1)
(u`(r*):=0 => r*=r*(a,b,L,m) )
i plotted the function for some values of b,a,L and m and i see that for certain values there is a minimum but i just can't figure out how do i find the right r.
can anyone help/give some hint?
b,a - constants
m - mass
If
[tex]U(r) = \frac{L^2}{2mr^2} - \frac{b e^{-ar}}{r}[/tex]
then, what you have written for U'(r) is not correct.
ok, the correct expression for u`(r):
u`(r)=L^2/m-b*r*(a*r+1)exp(-a*r)
still i don't quite know how to proceed...
How is that the correct expression?
What is
[tex]\frac{d}{dr} (\frac{1}{r^2})[/tex]?
and do you know how to find
[tex]\frac{d}{dr} (\frac{e^{-ar}}{r}) ?[/tex]
siddhart , so sorry
i simply already did some rearrangemnet:
[tex] \frac{du}{dr}=\frac{L^2}{mr^3} + \frac{b(are^{-ar} + e^{-ar})}{r^2}[/tex]
the expression i wrote is when i do
u`(r):=0
and i multiply by r^3
so sorry for confusion
Ok, by solving U'(r)=0, you can find the critical points and then you can find the points of minima with the second derivative test.On second thought, the equation you have to solve to find r looks really tough . I can find no obvious way to solve it.
For values of (ar)<<1, you could approximate by using the series expansion of [tex]e^{ar}[/tex]
i'll try to do that...
from the plots i did the r where u(r) is at minimum is very close to zero
i have to take only first term in [itex]e^{-ar}[/itex] expansion series otherwise i get an third order equation
Can you post your solutions for r when you get it? This is an interesting problem and I want to check that I got the right answers so I can show my classmates.
i asked my classmates about the solution and some say that there is no need to use expansion series...
i'm not sure what they did is right..so when i get the official solution(next week) i will give you a link to it
