How do i find the final velocity with 2 height variables and gravity
To find the final velocity of a tennis ball dropped from 1.3 m, use the equation for motion under gravity, where the initial velocity is zero. The time it takes to hit the ground can be calculated using the formula s = (1/2)at^2 + vt + s0, with a = -9.8 m/s^2 and s0 = 1.3 m. The rebound height of 0.956 m is not necessary for calculating the impact velocity but can be used to determine the velocity when leaving the ground. The change in momentum can be calculated using the mass of the ball and the time of contact with the ground to find the acceleration given by the ground. Energy methods can also be applied to solve parts one and two of the question.
deathslice246
1.A tennis ball is dropped from 1.3 m above the
ground. It rebounds to a height of 0.956 m.
With what velocity does it hit the ground?
The acceleration of gravity is 9.8 m/s^2
(Let
down be negative.)
Answer in units of m/s
2.With what velocity does it leave the ground?
3.If the tennis ball were in contact with the
ground for 0.0132 s, find the acceleration
given to the tennis ball by the ground.
Answer in units of m/s^2
You must show your attempt at the questions first. This can be any calculations, thoughts, misunderstandings etc..
What have you tried? You know, perhaps, that 'change in speed is equal to acceleration times time'? That comes directly from the definition of "acceleration". Here, the ball is "dropped" so the initial speed is 0 and so the final speed, the speed as it hits the ground is gt or -9.8t where t is the time the ball takes to hit the ground.
You can find the time, t, by using "s= (1/2)at^2+ vt+ s0" where a is the acceleration, v is the initial speed and s0 is the initial height. That's a bit more compicated formula but you should have seen it if you are asked to do a problem like this. As before, a= -g= -9.8 and v= 0. The initial height is s0= 1.3 m above the ground so when the ball hits the ground, s= 0.
So you want to solve (1/2)(-9.8)t^2+ 1.3= 0 for t and put that into v= -9.8t to find the ball's velocity when it first hits the ground.
The information that "It rebounds to a height of 0.956 m" is irrelevant to that but would allow you to do exactly the same thing to determine the velocity the second time the ball hits the ground.
ok let me try
it travels 1.3 m downwards right??
so it becomes -V2 -U2=2(-9.8)(-1.3)
as U=0 u can find The value of VNow Let velocity with which it leaves ground be u
At height 0.956m, Velocity is 0 Acceleration is -9.8(due to gravity)
using above equation u can get the velocity with which it leaves groundNow U can find the change in momentum by assuming mass of body = m
mv1(after hitting ground{Final momentum})-mv2(before hitting ground{initial momentum}) = change in momentum
Now force/\Deltatime gives us momentum
so m(v1-v2)=ma/\Deltatime(0.0132s)(assuming acceleration =a)
solve u should get acceleration
It's probably worth mentioning that parts 1 and 2 of your question can be solved by energy methods as well.
