How do I find the inverse of a log function?
4 replies · 25K views
hancyu
f(x) = log2 x + 3
2 log2 x − 1
how do i find the inverse of this? how do i find the range and domain of a log function?
f(x) = log2 x + 3
2 log2 x − 1
is equal to
f(x) = log2 x + 3 - log2 (x − 1)2
D of f(x) = R of f-1(x)
i tried changing the base but it didnt work...
also, is the inverse of
f(x) = 2x−1 + 3
log2 (x/3) +1 = y
f(x) = log2/3(x − 2) − 4
(2/3)x+4 + 2 = y
are these correct?
Ok. Your attempt was sadly, incorrect, although similar to something you were probably thinking of:
[tex]\log_c ( \frac{a}{b} ) = \log_c a - \log_c b[/tex],
which is not the same as what you tried: [tex]\frac{ \log_c a}{\log_c b} = \log_c a - \log_c b[/tex], which is not true.
It might help if you let [itex]u= log_2 x[/itex] so that you may view the problem easier. Doing so, solve the equation you have for you, replace the expression in x back in and solve it for x. Then swap your x and f(x), that's your inverse function!
For your second problem, not quite. Solve it for x first. So First take 3 to the other side,
[itex]2^{x-1} = f(x) - 3[/itex]. After that, take log_2 of both sides, hopefully you can see the rest. Then just swap x for f(x).
The last one looks correct, good work =]
Presumably you know that the domain and range of any function of the form loga(x) is {x|x> 0} and all real numbers respectively.
You also should know that the domain of a rational function is all numbers such that the denominator is not zero.
Putting those together, the domain of loga(f(x))/loga(g(x)) is all x such that x is positive and g(x) is not 1 (so that log(g(x)) is not 0).
so the domain of the 1st one is x=>0 ? because log can never be zero or negative?
i still can't get the inverse tho...
