How Do I Find the Y-int of a Curved Waveform?
  • Thread starter Thread starter Meadman23
The discussion revolves around determining the y-intercept of a curved waveform, specifically focusing on a segment that resembles a triangle. The original poster expresses confusion regarding the concept of a y-intercept in relation to the waveform's characteristics.
  • Participants explore the possibility of finding the y-intercept and question whether the original poster might actually be seeking the maximum y-value instead. There is a discussion about deriving equations for different segments of the waveform based on given points and slopes.
Participants are actively engaging with the problem, with some providing guidance on how to derive the equation for a specific segment of the waveform. There is a focus on using the point-slope form of a line to establish relationships between points and slopes, but no consensus has been reached regarding the y-intercept itself.
The original poster's inquiry is complicated by the fact that the waveform does not cross the y-axis in the specified range, leading to questions about the relevance of the y-intercept in this context.
Meadman23
If I have a waveform that looks like it does in the attached picture, how can I figure out the y-int at the point where the line curves like triangle?
This is confusing to me because I can figure out the slope of the triangle, but I don't see how there is a yint since the part of the form from x = 4 to x = 6 does not cross the y-axis.
Why do you want to find the y-intercept?
Are you sure you don't want to find y-max?
I figured that's the way I could solve for the function of this waveform.
That is, I could find the function of the part of the wave
1. from x = 0 to x = 4
2. from x = 4 to x = 5
3. from x = 5 to x = 6
Then, after I've deduced the correct functions that define each of the 3 parts of the waveform, I'd just add them up.
So, in my mind, since (2) is a slanted line, it must have an equation of the form y = mx+ b. m would simply be equal to [5-4]/[5-4] =1, but I don't see how I could get b.
To get the equation of the part of the waveform between x = 4 and x = 5, use the slope you found (1) and a point on the line. One of these appears to be (4, 4).
The point-slope form of the equation of a line gives y - 4 = 1(x - 4), which simplifies to y = x.
The point-slope form is:
Given a line with slope m, that passes through the point (x0, y0), the equation of the line is
y - y0 = m(x - x0)
Okay, let me see if I get this right.
1. The slope of (1) is [4-0]/[4-0] = 1
2. Using this slope and the point (4,4) and plugging it into the y - y0 = m(x - x0) equation yields :
y - 4 = 1(x - 4) -> y - 4 = x -4 -> y = x
3. From this, my equation for (2) is then shown to be y = x?
It's y = x for 4 ≤ x ≤ 5. The formula is valid on that interval. Other intervals have different formulas.
  • · Replies 69 ·
10K
