How do i integrate this "e^[−(x/xa)]
  • Thread starter Thread starter cutlerblows
    Integrate
cutlerblows
how do i integrate this "e^[−(x/xa)]
Does xa mean x*a, or is it a variable different from x?
Errr... Do you mean e^{\frac{x}{xa}} ? If so just cancel the x. You also need to show some working out and should have a more discriptive title. We are here to help not to do homework.
On the other hand if you mean xa, some fixed (constant) value, then use the substitution u= x/xa.
i meant x subscript a. but i figured out the answer. and fyi this is not my homework. I am studying for my physics test. but thanks for being rude...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
