How do I use heat to create cooling?
  • Thread starter Thread starter @nders
    Cooling Heat
Using heat to create cooling can be achieved through processes like absorption chilling, which utilizes heat to drive refrigeration cycles. The discussion highlights the importance of establishing a thermal gradient to effectively transfer energy from one location to another. For applications with significant heat sources, directly driving a turbine to power a conventional refrigerator compressor may be more efficient. Understanding the principles behind these systems is crucial for developing a functional device. Exploring these methods can lead to innovative cooling solutions.
@nders
Hi.
I'm looking for a easy way of using heat to create cooling. I am trying to make a device that will use the heat from one place, to cool something in another place down. Maybe this is more for the engineer forum, but what I need to know first of all is the names of the processes. For the cooling part is was thinking of using something like that, that is in a refrigerator. But first of all I don't know what it's, and I don't know how it works, since I don't know what to search after without a name for that process.
The refrigerator part obvious gets its power from the heat, but I don't know what device to use, to transform heat to power.
Cheers Anders
Science news on Phys.org
Heat is the motion of energy from one area to another area; what you want to do is setup some sort of gradient such that you can get the source (kinetic energy) and turn it into some destination, just like http://www.makezine.com/blog/archive/2006/06/diy_1000_watt_wind_turbine.html work. The more heat you have, the more gas-like or plasma-like your substance becomes, and plasmas are basically known to be moving so quickly that atoms are ripped into ions, etc.
- Bryan
A simple system http://en.wikipedia.org/wiki/Absorption_refrigerator
If you have a lot of heat or it is a greater distance away it might be better to use the heat source to directly drive a turbine and then use that to power a compressor in a conventional refrigerator.
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 32 ·
