How Do Mass and Length Correspond in Physics?
  • Thread starter Thread starter latentcorpse
    Length Mass
latentcorpse
The electron mass m_e = 10^6eV translates to a length scale \lambda_e = 2 \times 10^{-12}m
and the Planck scale has M_p=10^19GeV which translates to a length l_p \tilde 10^{-33}cm
i don't know how to show these masses correspond to these length scales. I'm sure it's fairly straightforward...can anyone help out?
thanks.
Use the formula
\lambda=\frac{\hbar}{mc}
You should be getting the 2 numerical values you mention.
yes but we are working in natural units so the formula would become \lambda=\frac{1}{m}, right?
then \lambda_e = \frac{1}{10^6}=10^{-6} which isn't what we want - so I assume I need to change the units of mass around or something?
You can't use \hbar=c=1 if your energies are still in units of eV.
A useful combination you should know is \hbar c = 197~\mathrm{MeV~fm} = 197~\mathrm{eV~nm}.
i thought that when we were in natural units, energy and mass were both measured in eV?
also how will \hbar c help when we have \frac{\hbar}{c}?
Maybe I'm misremembering, but my recollection is in natural units, you measure everything in terms of length. Maybe it's a theorist vs. experimentalist thing.
In any case, you can't just ignore the units you're given. In natural units, you have λ=1/m, so if λ is in units of length, then m is in units of 1/length, which is obviously not the same as an eV. You can't just plug the numbers in blindly. You have to convert the quantities to the proper units first.
\hbar c is a more natural combination than \hbar/c. Take the formula bigubau gave. What is mc? Nothing readily identifiable. On the other hand, mc2 you know is the rest energy of the particle. In terms of this quantity, you'd have
\lambda = \frac{\hbar c}{mc^2}
Note how the combination \hbar c appears in the numerator. This isn't an isolated instance. The same combination pops up all over the place.
You can also think of \hbar c as a conversion factor since
1 = \hbar c = 197~\mathrm{MeV~fm}
or equivalently
197~\mathrm{MeV} = 1~\mathrm{fm}^{-1}
or equivalently
thanks. i still seem to be a little bit out
\lambda = \frac{\hbar c}{E} \frac{197 \times 10^6 eVfm}{10^6 eV} \simeq 200 fm = 200 \times 10^{-15} m = 2 \times 10^{-13}m
and for the other one
\lambda = \frac{\hbar c}{10^{19} \times 10^9 eV} = \frac{197 \times 10^6 eVfm}{10^{22} \times 10^6 eV} = \frac{197}{10^{22}} \times 10^{-15}m \simeq 200 \times 10^{-37} m = 2 \times 10^{-35}m
Those are right. Note the Planck length you were given was in centimeters, not meters. I'd gather the other answer was just a typo.
