How do non-Hermitian Hamiltonians explain particle decay and quasi-bound states?
  • Context: Graduate
  • Thread starter Thread starter wofsy
    Non-hermitian
The discussion centers on the role of non-Hermitian Hamiltonians in explaining particle decay and quasi-bound states. Participants explore theoretical frameworks, mathematical implications, and the conditions under which these models apply, including the nature of eigenvalues and the conservation of probability.
  • Some participants explain that non-Hermitian operators can have complex eigenvalues, which may lead to particle decay through an exponential decay of state amplitudes.
  • There is a suggestion that the imaginary part of the eigenvalue is responsible for the decay, indicating a decrease in the probability of finding the particle over time.
  • Others caution that using non-Hermitian Hamiltonians is an approximate method, as it leads to non-conservation of probability and non-unitary evolution, which contradicts fundamental quantum mechanics principles.
  • A proposal is made that a more rigorous approach would involve a larger Hilbert space that includes both the unstable particle and its decay products, allowing for a Hermitian Hamiltonian and unitary evolution, thus conserving total probability.
  • One participant introduces the concept of quasi-bound states, where particles are not perfectly bound but exist within a finite barrier, leading to meta-stable eigenstates with imaginary components.
  • There is mention of specific boundary conditions that can lead to both decaying and growing solutions in time, suggesting a complex interplay between the Hamiltonian and the wave function behavior.
Participants express differing views on the validity and implications of using non-Hermitian Hamiltonians for modeling particle decay. While some agree on the role of complex eigenvalues, others highlight the limitations and need for more rigorous models, indicating that the discussion remains unresolved.
The discussion reveals limitations in the non-Hermitian approach, particularly regarding assumptions about probability conservation and the need for a broader framework to accurately describe decay processes.
wofsy
Can someone explain how non-Hermitian Hamiltonians are used to account for particle decay?
Hermitian operators always have real eigenvalues. Non-Hermitian operators can have complex eigenvalues. The evolution of an eigenstate of the Hamiltonian is ~exp(-iEt) where E is the energy. If E is complex, there could be a decay.
I infer from you terse reply that the decay is seen in the imaginary part of the eigen-value. It becomes an exponential decay of the state amplitudes. Yes?
Yes, imaginary eigenvalues mean that the probability of finding the particle decreases exponentially with time (decay). However, you should keep in mind that this is an approximate way to study decays. In this approach the probability is not conserved and the evolution is non-unitary, which contradicts basic postulates of quantum mechanics.
If you want to have a rigorous model of decays, you'll need to form a bigger Hilbert space, which includes states of both unstable particle and its decay products. In this Hilbert space the decay can be described by a Hermitian Hamiltonian and unitary time evolution operator. The total probability will be conserved, as required. The decreasing probability of finding the particle will be compensated by increasing probability of finding decay products.
very cool. Thanks
You could also consider cases where particles are not bound perfectly, but within a finite barrier. In such case you could find so called meta stable eigen states, which have imaginary components. The Hamiltonian is Hermitian though, but the boundary conditions are wave like at the boundary. Here the decay of the wave function is compensated by the fact that a current is produced outwards (or inwards) at the quasi bound domain, i.e.,
\frac{d\mid\Psi\mid^2}{dt}+\nabla\cdot\vec{j}=0
where the quantum current j is non vanishing. There are some simple cases where you could solve this exactly, like V=V0 for a<x<a+d and V=infinite at x<0 and else V=0. Eigenstates are normally degenerated symmetrically so that E=E0+/-i*Ej which means yo have both decaying and growing solution in time.
  • · Replies 22 ·
  • · Replies 67 ·
  • · Replies 23 ·
