How can crystals be used to generate signals and power?
  • Thread starter Thread starter WhoseYourPapi
    Work
PZT, or lead zirconate titanate, is a piezoelectric material that generates an electrical charge when mechanically deformed. This property allows it to produce a controllable voltage, but the energy output is typically small, making it challenging to use for charging batteries directly. Crystals can also be utilized to generate signals, particularly in transducers like microphones and as frequency sources when cut to resonate. The circuitry required to harness the power from PZT is complex, which has limited its widespread application. Despite these challenges, there is ongoing interest in the potential uses of piezoelectric materials.
WhoseYourPapi
sorry for bad engilsh . but I was wondering how PZT works i tried reading about it but it made no sense to me
what is the output ¿ like how can it charge a battery
does PZT when excited put out a controlable voltage or what
Crystals are made of atoms in a regular lattice.
Some atoms or combinations of atoms change their shape under an electrical charge; conversely they develop an electrical charge when deformed.
Thus the crystals made from those atoms share this property.
While technically this allows pressure on the crystal to develop a charge which could be used as power, the energies involved are small and the circuitry to do it is complex. Thus far it has resisted widespread application. Still, we keep hoping.
More practically crystals are used to generate signals. They are used in transducers (microphones) and, when cut to resonate, as frequency sources. In these applications other circuits amplify the small amount of power.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
