How do semiconductors affect a circuit?
Adding a p-n junction to a circuit, such as between a battery and a light bulb, significantly affects current flow based on the junction's orientation relative to the battery's polarity. When forward-biased, the p-n junction allows current to flow, illuminating the bulb, while reverse bias prevents current flow, effectively turning the bulb off. The p-n junction acts like a diode, permitting current in one direction and blocking it in the opposite direction. Understanding the operation of p-n junctions involves recognizing how they create electric fields and influence electron and hole movement. Mastery of semiconductors typically requires formal education, but their practical application in circuits is more straightforward.
Devguy101
I understand the difference between p-type and n-type semiconductors but I just don't understand how adding a
p-n junction to a circuit affects it.
Can someone please explain how semiconductors work?
For example, if I had a circuit with just a battery and a light bulb, what would change if I added a p-n junction right before the bulb?
The bulb would be on or off depending upon the direction of the p-n junction relative to the polarity of the battery.
An electronic part consisting of a simple pn junction is the DIODE. This part allows a current in one direction only - of course, caused by a corresponding voltage of (0.6...0.7) volts (forward operation). If you change the polarity of the voltage there will be no current (backward operation, off condition). Under this condition, the diode behaves like a very large resistance (nearly infinite).
Really I think you need to ask this as 2 questions...1) How does a PN junction work? 2) How does this affect a circuit - how is it used? I say this because you do not need to completely understand one to understand the other.
When a voltage is applied on a PN junction you are said to "bias" the junction - and sets up an electric field in the semiconductor. In the forward mode the "holes" in the P side and Electrons in the N side are pushed together by the electric field in the diode - when an electron - combines with a hole this in essence allows current flow. It is a lot more complicated but that is as simple as I can state it. In the reverse bias, the Holes and Electrons are pulled away from each other, they can not combine - and they can not conduct current.
As for use - think of the device as a one-way valve.
BTW introduction to semiconductors is a full semester EE, or Solid State Physics class - the HOW they work... granted it covers much more than diodes. I am not saying you need a semester class, but you probably can not figure it all out in a forum without a lot of research on your part. But note the Use side, how Diodes and other basic semiconductors are applied, is typically only a part of a circuit analysis course. - Using them is easier than understanding them.
Likes Devguy101
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
