How Do You Apply the Washer Method for Calculating Volumes of Revolution?
  • Thread starter Thread starter karamsoft
    Method
The discussion focuses on applying the washer method to calculate volumes of revolution for the region bounded by the curve y = √x, the line y = 2, and the vertical line x = 0, over various axes. The volume calculations provided include revolutions around the x-axis, y-axis, the line y = 2, and the line x = 4, yielding results of 42.265, 8.3775, 8.3775, and 46.9144 cubic units respectively. Key feedback highlighted the importance of using parentheses in the integral expressions to avoid confusion in calculations.
  • Understanding of the washer method for volume calculation
  • Familiarity with integral calculus
  • Knowledge of functions and their graphs, specifically y = √x
  • Ability to manipulate and evaluate definite integrals
  • Study the washer method in detail, focusing on its application in different scenarios
  • Practice evaluating definite integrals involving square roots and polynomials
  • Learn about the disk method as an alternative to the washer method
  • Explore common pitfalls in volume calculations, particularly with parentheses in integrals
Students studying calculus, educators teaching volume calculations, and anyone seeking to master the washer method for finding volumes of revolution.
karamsoft
Use the washer method to find the volume of hte solid generated by revolving the regions bounded by y= root(x) and the lines y =2 and x=0 about the x-axis , y-axis , y= 2 and x=4
V= Pi integral (0,4) (R(x)^2 - r(x)^2) dx
I tried to use the equation above but I totally got confused about r(x)^2 as from what I know that the washer method means you have a small radius that you will subtract from the large curve which is in this case root(x) but there is none!
Thank you very much for your time, I would appropriate if you could explain how you solve this question so I could learn
I tried to solve these problems in a different way but I'm not sure if I'm on the right track.
If it revolved over the x-axis then the volume will be
integral (0,4) Pi (2)^2 - (root (x))^2 dx = 42.265 units^3
If it revolved over the y-axis then the volume will be
integral (0,2) Pi (y)^2 - 0 dy = 8.3775 units^3
If it revolved over the line y=2 then the volume will be
integral (0,4) Pi (-root(x)+2)^2 dx = 8.3775 units^3*****This is the one that I'm not really sure if its the right answer or Not so please HELP!
If it revolved over the line x=4 then the volume will be
integral (0,2) Pi ((4)^2 -(-y^2+4)^2) dy = 46.9144 units^3
[tex]\int_0^4 \pi\left(2^2-(\sqrt{x})^2\right)\,dx[/tex]
You're missing a set of parentheses.
You missed the parentheses here too, but the numerical answer is OK, because zero times pi is zero.
This looks OK.
This looks OK too.
  • · Replies 16 ·
