How do you calculate density of a vapor only vapor pressure and temp.
To calculate the density of mercury vapor in a saturated air environment, the ideal gas law can be applied. The formula n/V = P/RT allows for determining the molar density, where P is the vapor pressure and T is the temperature in Kelvin. By converting the resulting moles per cubic meter into atoms using Avogadro's number, the total number of mercury atoms can be found. The discussion highlights the importance of recognizing unit conversions, such as liters to cubic meters. Understanding these concepts is crucial for accurately calculating vapor density.
aleksbooker
Hello all,
The question given is:
Mercury and many of its compounds are dangerous poisons if breathed, swallowed or even absorbed through the skin. The liquid metal has a vapor pressure of 0.00169mmHg at 24 degrees Celsius. If the air in a small room is saturated with mercury vapor, how many atoms of mercury vapor occur per cubic meter?
I can't use Clausius-Clapeyron because I only have one pressure and one temperature to work with, and I can't use PV = nRT, because I don't know how many moles of mercury I have. If I arbitrarily increase the moles, I increase the volume just as quickly, which may not affect density, but either way I don't know the concentration of moles per liter. I even considered the pressure = force/area, but that's not relevant to volume.
I'm certain the fact that the air is saturated is somehow key, but I can't find anything in my textbook that seems to address this question. What am I missing?
Thanks,
Aleks
Hi Aleks. Welcome to Physics Forums!
You can use the ideal gas law. You first need to find out how many moles of mercury there are in each cubic meter. From the ideal gas law, the molar density is \frac{n}{V}=\frac{P}{RT}. This has units of moles per cubic meter. You then multiply by Avagado's number to get the number of atoms per cubic meter. In this equation, P is the vapor pressure at 24 (room temperature) and you use T = 273+24.
Chet
Thanks, Chet!
It took some fishing, but I figured it out. I didn't consider that liters could be converted into cubic meters.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
