How Do You Calculate Enthalpy Using Steam Tables and Dryness Fraction?
  • Thread starter Thread starter sperrya
    Steam
The discussion revolves around calculating the enthalpy of steam using steam tables and the concept of dryness fraction. Participants explore the application of steam tables in determining enthalpy values for specific conditions, including pressure and dryness fraction.
  • Homework-related
  • One participant presents a calculation for the enthalpy of steam at 0.4 MPa and a dryness fraction of 0.7, using values from steam tables.
  • Another participant confirms the correctness of the initial calculation and suggests a more concise formula for calculating enthalpy.
  • A participant seeks clarification on how to apply the suggested formula to their calculations, specifically asking about the meaning of the variable 'x' in the equation.
  • The same participant later defines 'x' as the dryness fraction, equating it to 0.7.
There is agreement on the correctness of the initial calculation, but some uncertainty remains regarding the application of the alternative formula and the meaning of specific variables within it.
Participants express varying levels of familiarity with steam tables, indicating potential gaps in understanding how to apply them effectively in calculations.
sperrya
Find the enthalpy of steam at 0.4 MPa and 0.7 dryness
At a pressure of 0.4MPa dry saturated steam has a total enthalpy of hg = 2,739 kj/kg.
∴ 0.7 kg of steam has an enthalpy of (0.7 x 2,739) = 1917.3 kj
The total heat of 0.3kg of water is 0.3hf (at 0.4MPa), so 0.3 x 604.8 = 181.44 kj
∴ Total heat for wet steam = 181.44 + 1917.3 kj/kg
= 2,098.74 kj/kg
This is my first time using steam tables so am struggling to know if I am gripping it or not. Any help you can offer in order for me to answer this question is VERY much appreciated.
Regards
Yes, your answer is correct.
Your method is correct but it might take a little longer to do if you are in an exam. (the same formula with less lines would be)
h = hf+ xhfg= hf+x(hg-hf)
(Your steam table might have values for hfg sometimes)
Formula is the same for specific entropy and specific volume in that
s=sf+xsfg
v = vf+xvfg
Thank you rock.freak667
Hi rock.freak667,
Sorry, can you just clarify how my calculations would fit into that equation?
I can follow it through but I am unsure what your X stands for? Can you clarify.
hf + x (hg - hf)
∴ 604.8 + x (2739-604.8)
∴ 604.8 + x (2134.2)
Can you clarify for me?
thanks a lot
sperrya said:
Hi rock.freak667,
hf + x (hg - hf)
thanks a lot
x = dryness = 70% = 0.7.
9K
  • · Replies 50 ·
12K
11K
