How Do You Calculate Kinetic Energy and Momentum for Spaceships in Motion?
The discussion focuses on calculating the kinetic energy and momentum of two spaceships, a Vulcan and a Romulan, with given masses and engine force. The Vulcan spaceship has a mass of 65,000 kg, while the Romulan is twice as massive, and both generate a force of 9.5 x 10^6 N for 100 seconds. The initial calculations for the Vulcan's kinetic energy and momentum are presented, but a participant suggests a more efficient method using impulse to reduce error and save time. The conversation concludes with an acknowledgment that the alternative approach is more straightforward and will be useful for future calculations. Understanding these principles is essential for accurately determining kinetic energy and momentum in physics problems.
yellowgators
A Vulcan spaceship has a mass of 65,000 kg and a Romulan spaceship is twice as massive. Both have engines that generate the same total force of 9.5 x 10^6 N. Neglecting any changes in mass due to whatever is expelled by the engines, calculate the kinetic energy and momentum of each spaceship if each spaceship fires its engines for 100s, starting from rest.
K=1/2mv^2
p (momentum)=mv
First I dealt with the Vulcan:
F=ma--> F/m=a 9.5 x 10^6 N/ 6.5 x 10^4 kg= 146 m/s^2
Vf-Vi=a(delta-t) Vf=146m/s^2(100s)=14600 m/s^2
K=1/2mv^2=1/2(6.5 x 10^4kg)(14600 m/s)^2= 6.93 x 10^12 J
p=mv=(6.5 x 10^4kg)(14600m/s)=9.49x10^8 kg m/s
I just need to know... Am I on the right track? Are there factors I'm not taking into account?
K=1/2mv^2
p (momentum)=mv
I'm not checking your arithmetic, but your method seems good to me :approve:.
Thanks!
touche yellowgators!
I only have 1 reproche; the method that you used makes the percent of error higher than it schoul really be. In addition your method is time consuming. Try using this method next time:
1)P=F*t=(m*v1)-(m*v2) ****v1 is initial velocity and v2 is final velocity*******
The impulse P = 9.5 x 10^6 N * 100s
P=9.5 x 10^8 N*s
2) v2 is found by:
P=(m*v2)-(m*v1) *******v1 equals to 0 *******
P=m*v2
v2=9.5 x 10^8 N*s/6.5 x 10^4 kg = 14615.38m/s
3)Potential energy(PE) = F*d
PE=9.5 x 10^6 N* (14615.38m/s/2) *100s ****d=average velocity*time********
PE=6.94*10^12J
A difference of 0.01*10^12 might not seem much but look at it again :10000000000. Wow, that is a big number!. that number schould really be larger because i aslo rounded.
well, here you go
I looked over that method. Thanks! Using the law of conservation of energy is more straightforward than how I approached the problem. That will be helpful for future problems.
