How Do You Calculate the Lift Force of a Jack Screw?
  • Thread starter Thread starter rambo 3504
    Calculation Lift
The discussion focuses on how to calculate the lift force of a jack screw, particularly in the context of a mechanical system similar to a car jack. Participants explore different approaches to solving the problem, including static analysis and kinematics.
  • Homework-related, Technical explanation
  • One participant inquires about the appropriate formula for calculating the lift force of a jack screw given the force exerted on it.
  • Another participant suggests using free body diagrams (FBDs) for the links and setting it up as a conventional statics problem, or alternatively employing kinematics and virtual work.
  • A third participant expresses gratitude towards the second participant for their input.
  • A participant shares a free body diagram (FB) of their linkage for further discussion.
The discussion does not present a consensus on a single method for calculating the lift force, as multiple approaches are proposed without resolution.
rambo 3504
What formula would I use to calculate the lift force of a Jack Screw
when I know the force exerted on the linear screw? It would be similar to the Jack used to lift a car.
Well, you could draw FBDs for the links and set it up as a conventional statics problem,
or,
you could do some kinematics and use virtual work. Your choice!
Thanks Dr.D
Here is a FB of my linkage.
  • · Replies 69 ·
