How Do You Calculate the Magnetic Field Near a Solenoid?
The discussion revolves around calculating the magnetic field near a solenoid and two parallel wires carrying current. The original poster presents a scenario involving a solenoid with specific dimensions and current, seeking to determine the magnetic field at a point near the wires.
  • Participants explore the appropriate formula for calculating the magnetic field, questioning whether to use the solenoid equation or an alternative for parallel wires. There is discussion about the relevance of distances from the wires and the solenoid, as well as the direction of the magnetic field.
Participants are actively engaging with the problem, clarifying assumptions about the distances involved and the configuration of the wires. Some guidance has been offered regarding the use of different equations based on the proximity to the solenoid versus the wires.
There is uncertainty regarding the exact locations of point A relative to the solenoid and the wires, which affects the choice of equations. The original poster has provided a diagram, but its clarity is questioned by other participants.
SamL
A pair of wires carry a current I=2.4 A to and from a solenoid. The solenoid contains 600 coils of wire wrapped in a cylinder 15 cm long and 1 cm in diameter.
a.) What is the magnitude and direction of the magnetic field at point A d1= 5 mm from the near wire and d2= 7 mm from the far wire?
B=(m0*N*I)/l
We know m0, N, and I but I'm not sure if the length is supposed to be the 5 mm or 15 cm? Obviously which ever I use I'll have to convert to meters. Do I just plug that stuff into the equation above and I'll have the answer? After I find the magnetic field magnitude with the equation, I'll use the right hand rule to find out which direction it points.
The length will be the length of the solenoid; the field depends upon the number of turns per unit length.
It's not clear from your problem statement exactly where the points in question are located with respect to the solenoid: So many millimeters away from a wire could be in any direction. How are we to know what is the "near wire" and the "far wire"? Also, the field direction is going to depend upon the current direction and the sense of the winding. Was a diagram included with the problem?
Yes it was. I thought I posted it already. Sorry, here it is
this is easier to view without having to open pesky pdf files ...
So it looks like point A might be nowhere near the solenoid; the distance of point A from the solenoid is not given. It is, however very near the two wires. Does that suggest anything to you?
So if it's nowhere near the solenoid, I don't use the solenoid equation, B=(m0NI)/l? Is that what you're saying? Would I use B=(m0/2pi)(I/d) since the wires are in parallel right there and not all twisted up like a solenoid? The d value would be either d1 or d2, depending upon which I chose to do first, and the I value would 2.4 A. Is that correct?
Yes it is. And the magnetic field at point A is superposition of the two magnetic fields.
That's the idea.
By the way, you can access Greek letters and other symbols via the ##\Sigma## icon in the edit panel, in case you want to write μo rather than m0.
Awesome thanks! :)
  • · Replies 31 ·
  • · Replies 21 ·
10K
