How Do You Calculate the Mass of Tetraethyl Lead in Gasoline?
  • Thread starter Thread starter blazer105
    Chem Grade 11
To calculate the mass of tetraethyl lead in 31.2 L of gasoline, the formula used involves the density of tetraethyl lead (1.653 g/mL) and the concentration added (2.0 mL per 3.8 L of gasoline). The initial calculation was nearly correct but had minor unit issues. For the second part, determining the mass of elemental lead requires using molar masses. The discussion highlights the importance of unit conversion and the application of molar mass in chemistry calculations.
blazer105
Hi I have two questions grade 11 chem questions that I don't know how to do. HELP PLEASE!
Q1: Tetraethyl( Pb(C2H5)4 ) lead was added to gasoline up to 2.0ml per 3.8L of gasoline.
a)Calculate the mass of Tetraethyl lead in the total amount of gasoline that you use for this trip (31.2 L of gasoline). The density of Tetraethyl lead is 1.653g/mL
b) Calculate the mass of elemental lead in the total amount of gasoline that you will consume for this trip.
I'm not sure but here is what I did.
Mass tetraethyl lead = 31.2 L gasoline * (2.0 mL Pb(C2H5)4/3.8 L gasoline) * 1.653 g Pb(C2H5)4
Looks correct. Well, almost correct - not all units are OK. But that's a minor problem.
b is about using molar masses.
Yeah thanks for the help... I got the question like 12 mins after posting thanks for your help tho.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
