How Do You Calculate the Minimum Velocity to Escape the Solar System?
The discussion focuses on calculating the minimum velocity required for an object to escape the solar system, considering the gravitational influences of both the Earth and the Sun. Participants explore the relationships between escape velocities from these two bodies and the implications of Earth's orbital motion.
  • One participant presents equations relating escape velocities from Earth and the Sun, expressing uncertainty about their derivation.
  • Another suggests calculating escape velocity from Earth and then from the Sun, noting that the rocket retains Earth's orbital velocity upon launch.
  • Some participants argue that Earth's orbital velocity is not beneficial for escaping the solar system, as it is perpendicular to the necessary radial direction from the Sun.
  • One participant asserts that escape velocity is independent of trajectory direction, as long as the trajectory does not intersect the body being escaped from.
  • A detailed derivation of the escape velocity formula is provided, incorporating energy conservation principles, but the contributor expresses uncertainty about its correctness.
  • One participant acknowledges the helpfulness of a previous reply in addressing their problem.
Participants express differing views on the relevance of Earth's orbital velocity in the escape calculations, indicating a lack of consensus on this aspect of the problem.
Some assumptions about the trajectory and the influence of gravitational forces are not fully explored, and there are unresolved mathematical steps in the derivation presented.
Ed Quanta
I have to solve a problem regarding the minimum velocity required to escape from the solar system while taking into account the gravitational force of the Earth as well as the sun. What I am supposed to do is calculate the velocity of an object after escaping from earth. Then I am supposed to go to a sun fixed frame and calculate the minimum velocity for escape from the sun. The answer that I am striving for is the following:
v^2= v(escape from earth)^2 +v1^2
v1=v(escape from sun) - v(orbit)
I am not sure how these equations above are derived. I can calculate the escape velocity for the sun and earth, but I am not sure how to relate these two separate frame.
Astronomy news on Phys.org
calculate your escape v from Earth.
Calculate your escape velocity from the sun at Earth's distance.
Now the Earth is alrady moving with respect to the sun and the rocket was lauched from the Earth, so it carries this velocity with it. Thus thus you can subtract the Earth's orbital velocity from the escape v from the Sun, to get the amount of velocity you need to add to your ship in order to leave the solar system after escaping the Earth.
Earth's orbital velocity won't help. It is pointing essentially perpendicular to the sun-earth line. To get out of the solar system, you need a radial (from the sun) high speed.
No, Escape velocity is escape velocity, The direction doesn't matter (as long as your trajectory doesn't intersect the body you are trying to escape.) If you attain escape velocity while traveling perpendicular to the radius vector, this means you are at the periapis of a parabolic orbit, one that will take you out of the Solar system.
I will give you a derivation of the formula, but I am not completely sure whether it is correct.
Take v as the required escape velocity, m the mass of the rocket or object which is going to escape, Me the mass of the earth, Ms the mass of the sun, re and rs the radius of Earth and the distance from the sun to the Earth respectively, v_es escape velocity from sun, v_e escape velocity from Earth and v_o orbital velocity of earth.
As already mentioned, escape velocity is escape velocity, and it should not be dependent on trayectories and so on.
Thus, consider an rocket escaping from the Earth and going to a point in the Earth's orbit, which is far from the influence of the Earth's gravitational field. Consider also velocities only relative to earth. In such a situation the required velocity to escape the sun is (v_es - v_o).
Aplying energy conservation to this situation in relation to the launch of the rocket:
½ m v^2 - (G Me m) / re - (G Ms m) / rs = ½ m (v_es - v_o)^2 - (G Ms m) / rs
½ m v^2 - (G Me m) / re = ½ m (v_es - v_o)^2
Since (2 G Me) / re = v_e^2, then
v^2 = v_e^2 + (v_es - v_o)^2
Regards.
I just had to mention that this reply was really helpful in solving one of my problems as well. Thank You!
  • · Replies 122 ·
10K
  • · Replies 27 ·
