How Do You Calculate the Number of Electrons in a Mole Using Faraday's Constant?
  • Thread starter Thread starter david2120
    Determination
To calculate the number of electrons in a mole using Faraday's constant, the charge per mole (3.407x10^-8 coulombs/mole) is divided by the charge of a single electron (1.60x10^-19 coulombs). This method determines how many electrons correspond to the given charge. The calculation results in approximately 2.13x10^11 electrons per mole. The initial value of 3.407x10^-8 coulombs/mole was questioned for accuracy, with suggestions that it may be off by a factor of 10^12. The discussion emphasizes the importance of proper unit conversion in such calculations.
david2120
using the number obtained 3.407x10^-8 coulombs/mole and the fact that one electron has a charge of 1.60x10^-19 coulombs, calculate how many electrons there are in one mole (i.e. Avogadro's number)
I am not sure but do you do this problem like this?
3.407x10^-8coulombs/mole x 6.022x10^23electrons/mole divide 1.60x10^-19coulombs
Yep, that looks good to me.
~H
Please state the entire question - not just a part of it. Where was the number 3.407... obtained from ?
That doesn't look right to me (for one thing, it has units of [mole^-2] which are meaningless), but neither does the question as posted.
david2120 said:
using the number obtained 3.407x10^-8 coulombs/mole and the fact that one electron has a charge of 1.60x10^-19 coulombs, calculate how many electrons there are in one mole (i.e. Avogadro's number)I am not sure but do you do this problem like this?
The huge problem here is that you (improperly) used the number of electrons in a mole to determine...the number of electrons in a mole.
The problem basically boils down to "how many electrons does it take to give a charge of 3.407e-8 C.
Again as it was said above, the first given number is a bit suspicious...
In Lab I did an experiment in class on trying to determine Faraday's constant and I got 3.407x10^-8 and I have to used that on my calculations
Well I hate to break your hopes but you're off by a factor of 1012.
But yes like I said you just want to determine how many electrons it would take to get the charge that you experimentally determined. It's just a simple factor label problem. You are given C/m (Coulombs per mole) and want to determine N/m (number of electrons per mole) given C/N (Charge per electron)
oh so its 3.407x10^-8 C/m divide 1.60x10^-19coulombs which equals to
2.12938E^11 N/m (number of electrons per mole)
