SammyS said:
I never said to divide by 4. You may have interpreted it that way because I said " KEtotal = 4·KEindividual ".
Work with the system as a whole and use conservation of energy to find the Kinetic Energy (KEtotal) of the system when the particles have doubled their distances from center of the square (i.e., when ALL the mutual distances have doubled).
Then, (Now I say it for the 1st time) divide KEtotal by 4 to find KEindividual - KE for each particle.
You are correct in not wanting to divide total energy by 4 ( although it can give the correct answer ) because it makes no sense to divide potential energy, U, of the whole system by 4.
flyingpig said:
Now I am really confused should I divide it by four or not?
Should multiply by the system by 4 which will then be the total KE?
You need to be more specific than "
it".
I thought I was very clear. To repeat, "... divide KE
individual ..." Maybe the hyphen confused you so I omitted it here.
flyingpig said:
Wait, forget that one. The sum of energy has nothing to do with the change in energy
\Delta U = kq^2\frac{4+\sqrt{2}}{4L} - 0 (for the initial energy is 0 since they were infinitely far away)
\Delta U = kq^2\frac{4+\sqrt{2}}{4L} = -\Delta K
Now I am stuck, I can't take negative square roots.
(Yes, you can take negative square roots. What's a problem is taking the square root of a negative number. I.e. ‒√(5) is OK, (so is √(‒x), if x < 0). However, √(‒7) is a problem if you're expecting a real number result. )
Now, to address the main issue here: The initial
Kinetic Energy is zero. Therefore, the initial energy (Total Energy by default) is the initial Potential Energy, U.
Your initial PE (of the system) was:
\sum U = kq^2\left(\frac{4 + \sqrt{2}}{L} \right )\ .
Your final PE (of the system) should be:
\sum U = kq^2\left(\frac{4 + \sqrt{2}}{2L} \right )\ .
(Found by using 2L instead of L.)
PE
initial+KE
initial = PE
final+KE
final ←
This is for the system.
The final KE for the system is given by:
\text{KE}=kq^2\left(\frac{4 + \sqrt{2}}{2L} \right )\ .
This is the sum of the KEs for all 4 particles. By symmetry, you can infer that each particle has 1/4 of this as its KE when their distance from each other has doubled.
