How Do You Calculate the Time for a Mass to Fall Using Moment of Inertia?
  • Thread starter Thread starter jago-k1
    Moment
The discussion focuses on calculating the time it takes for a hanging mass to fall 31.5 cm using the moment of inertia. The user presents their attempts at solving related problems, including calculating the moment of inertia for a two-mass system and determining rotational kinetic energy. They correctly compute the moment of inertia for a support rod and shaft and seek assistance in deriving the time for the mass to fall. The thread emphasizes the application of physics equations related to energy and motion, highlighting the user's need for clarification on the final calculation.
jago-k1
How long does it take for the hanging mass to fall the same distance 31.5 cm?
I don't know how to solve for T with everything I have. Help please.
mgh=(1/2)I(2h/tr)2 + (1/2)m(2h/t)2
Okay, previous questions are[All correct]
1.
Two masses of 150. g are suspended from a massless rod at a distance of 9.0 cm from the center. What is the moment of inertial of the two-mass system about the center of the rod?
I=m1*R^2
since they are two masses that weigh the same
I= 2(.15kg)(.09m)^2=2.43E-03 Correct
2.
If the masses rotate with an angular velocity of 2.45 rad/s, what is the rotational kinetic energy of the system?
KEr=(1/2)Iw^2 = (2.43E-03 )(2.45 rad/s)^2 = 7.29E-03 J Correct
3.
Consider the setup shown in the lab manual but with the large masses removed from the support rod. If the hanging mass is 100. g and drops a distance 31.5 cm in a time of 6.1 s, what is the moment of inertia of the support rod and shaft? The radius of the shaft is 0.50 cm.
I=mr^2(gt^2/2h - 1) = 1.446E-03 kg m^2 Correct
4.
Now two masses each of 200 g are placed on the rod at a distance of 11.0 cm from the point of rotation. What is the TOTAL moment of inertia of the masses plus rod and shaft?
Yes, Computer gets: 6.286E-03 kg m^2
I=2MR^2+Io is what you get from #3
I=2(.2kg)(.11m)^2 + Io = 6.286E-03 kg m^2 Correct
BUMP if anyone can help out.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
