How Do You Calculate Thrust and Resultant Force for Saturn V Rockets?
To calculate the thrust produced at lift-off for the Saturn V rocket, one must apply the principles of conservation of momentum and Newton's laws. The thrust can be determined by analyzing the change in momentum of the gas ejected during a specific time interval. The resultant force acting on the rocket at lift-off is the difference between the thrust and the weight of the rocket. Clarification on the problem's parameters may enhance understanding and calculations. Overall, a solid grasp of impulse and force duration is essential for accurate calculations.
pluke100
Guys got this question and couldn't do it.
The Saturn V rockets which launched the Apollo space missions had the following specifications:(look at attached pic)
Caulculate i) the force(thrust) produced at lift
ii) the resultant force acting on the rocket at lift-off
Looks like you should use conservation of momentum and Newton's laws. What did you do?
Also, the problem is a little vague, maybe you could clear it up a little.
i haven't got an idea what to do with that :S
Change in momentum is the impulse, which for a constant force is the product of force times the duration of the force. Find the change in momentum of the gas ejected by the rocket in some small time interval Δt and go from there.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
