How Do You Calculate Work and Internal Energy in Thermodynamics?
  • Thread starter Thread starter buttterfly41
    Thermodynamic
The discussion revolves around calculating work and internal energy in thermodynamic processes involving gases. For the first scenario, the user struggles with calculating work done by a gas during compression and seeks clarification on unit conversions, emphasizing the need to use consistent units. In the second scenario, the user attempts to calculate work for gas expansion and compression but faces issues with unit discrepancies, indicating a need for careful unit management. The third scenario involves determining the mass of helium based on work done and temperature change, with suggestions to use the ideal gas law and specific heat differences for accurate calculations. Overall, the thread highlights the importance of unit consistency and the application of thermodynamic principles in problem-solving.
buttterfly41
1. A gas is compressed from 10.00 L to 2.00 L at a constant pressure of 0.800 atm. In the process, 400 J of energy leaves the gas by heat.
(a) What is the work done by the gas?
(b) What is the change in its internal energy?
so for part a, i have tried:
P*deltaV=W
8.106E4 * 8 = 6.48E5 for the answer to part a, it is wrong and i don't know how else to approch this. I put the pressure in Pa, but maybe i should have left it in atm? i don't know, any help would be wonderful. And for part b, i know that Q-W=U, so i should be able to get b, once i figure out part a.
2. Gas in a container is at a pressure of 1.30 atm and a volume of 3.00 m3.
(a) What is the work done by the gas if it expands at constant pressure to twice its initial volume?
(b) If it is compressed at constant pressure to one quarter of its initial volume?
So far for part a, i have tried:
W=P*delta V
1.32E5 * 3000L = 3.96E8 J, but this isn't right...
I also tired:
W=Pln(vf/vi)
1.32E5* ln(6000/3000) = 9.15E4 J... again wrong
not sure what else to try, and again, part b will be much the same once i understand part a
lastly,
3. A sample of helium behaves as an ideal gas as energy is added by heat at constant pressure from 273 K to 393 K. If the gas does 15.0 J of work, what is the mass of helium present?
so i have tried:
Q=mc*deltaT
15=m*5.193*120
m=.0241moles *4g/mol = .0482g... but wrong
Any and all help/suggestiong would be much appreciated thankyou.
Question 1.(a) seems a logical place to begin. Think about question (a) again; is the gas doing work or are you doing work on the gas?
W=P*delta V
Your method is correct (dW = PdV so W = \int dW = P\int dV = P(V_f - V_i)). Check your units. If you are using MKS you cannot use litres.
so i have tried:
Q=mc*deltaT
15=m*5.193*120
Since you know that PV = nRT, create an expression for W in terms of temperatures and determine n from that.
I am not sure of your thinking using the heat approach.
Since dQ = nC_pdT = dU + dW = nC_vdT + PdV you can work out n. What is the difference in specific heats (Cp - Cv)?
AM
thanks to both of you, i was confused, but i get it now! THANKS1!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
