How do you determine wavelength, x, from this expresstion?
  • Thread starter Thread starter Obelisk
    Wavelength
Obelisk
The problem is a semiconductor question which I have resolved and gotten the equation:
w = (50.12 x) ^ 0.5
From the knowledge of this system, x is in an interval such that 0.5 < x < 2.5
What mathematical method of solution would help find the solution to this equation? The value of x is supposed to be the minimum practical value for the solution.
Thanks.
w = (50.12 x) ^ 0.5
Thanks.
You solve an equation by "backing out". Since the last thing done or the right was "0.5 power", which is the same as square root, so the opposite: square both sides. Then you are left with just 50.12x on the right. Since x is multiplied by 50.12, do the opposite: divide both sides by 50.12.
Thanks for your ideas so far.
Well, by squaring it and/or dividing it by 50.12, I am not going to be able to obtain the value of x still which should be in the interval 0.5 < x < 2.5 (from the theory of the physical problem).
The value of w is unknown and the only way of finding it is by solving for this equation.
Thanks again.
Apparently you want to find the interval for w if 0.5 < x < 2.5 in this function:
w = (50.12 x) ^ 0.5
I interpreted your original post as wanting to find x.
The function above is an increasing function, meaning that as x increases, so does w. On the interval 0.5 < x < 2.5, the smallest value of w will be for x = 0.5; the largest value for w will be for x = 2.5.
Is that what you're looking for?
Thank you all for your help so far.
Well, I have used another approach in resolving this this problem but I am wondering if anyone could suggest a way to simplify this further. I wish to express this equation in terms of x:
d = 10^-20 x^(-18/4) x^-1.
So, is there a way to write this equation in the form: x = ... ??
I have checked my solution with numeric values which seems fine but I need to express in that form, please help. Thanks.
To Mark44, HallsofIvy and other members who helped or looked into my posting, thanks so much!
The good news is I finally resolved the problems and I am so glad I can now move on!
I just wish I knew clearly what those problems were!
