How do you find instantaneous speed?
  • Thread starter Thread starter navneet
    Speed
To find instantaneous speed at t=6 seconds, one can analyze the provided distance-time data points. Using a graph and drawing a line of best fit can yield a similar result to applying mathematical formulas for instantaneous speed. Both methods essentially involve curve fitting, which approximates the speed at that specific time. The discussion emphasizes that a graphical approach is valid and may be more intuitive for some. Ultimately, both methods should provide comparable results for determining instantaneous speed.
navneet
how can I find the instantaneous speed when t=6 seconds for the following, and would it be any differnt if i draw a graph and find it using with the line of best fit.
d (m) l t (s)
0 l 0
2 l 1.59
4 l 2.37
6 l 3.87
8 l 3.98
10 l 6.09
12 l 8.90
14 l 8.66
16 l 9.23
18 l 10.18
Your approach is probably the most reasonable. There are formulas one could use, but they would effectively get the same result as you could by a good curve fit. The formulas are curve fitting themselves.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
