How do you find the displaced amplitude of sound?
  • Thread starter Thread starter keighley
    Amplitude Sound
To find the displaced amplitude of sound from a loudspeaker vibrating at 2kHz with a pressure of 55.1 N/m², the relevant parameters include air density (1.59 kg/m³) and the speed of sound (340 m/s). The wavelength is calculated to be 0.17m. The speaker's dimensions are deemed unnecessary for solving the problem. The original poster later confirmed they found the solution and planned to share their method.
keighley
A loudspeaker of 30cm diameter vibrates at 2kHz. Given that the pressure generated is 55.1N/m2, determine the displaced amplitude.
Assume air density is 1.59kg/m3 and that the speed of sound is 340m/s.
I have been told that the dimensions given for the loadspeaker is a red herring and not needed in the solution of hte question.
v = Velocity = 340m/s
f = Frequency = 2kHz = 2000Hz
 = Wavelength =
Wavelength  = 0.17m (170cm)
Welcome to PF :smile:
I don't know the answer myself, but is there nothing in your textbook or class notes relating the amplitude of vibration for sound waves?
p.s. some characters you are typing are not showing up properly, for example in "xxx = Wavelength =", the "xxx" (whatever that is) does not show up.
Yes I saw the missing characters after I posted it.
I worked it out after I posted the message.
I have the answer at work so I will post it and how I got it later.
